Results 1 to 16 of 16
Thread: NC State Exam
11-18-2014, 09:31 PM #1
NC State Exam
Hello, I have just finished my online(120 hrs)through AHIT and awaiting to go through the in-class in-field)training in Feb then take final exam in June. My question is does anyone know type of questions or how to study for it. I have heard a lot of question are code related. I also understand that NC is a very tough state. I appreciate any feed back. Thx Gary
11-19-2014, 07:52 AM #2
Re: NC State Exam
I'm not in or from NC, but the above puzzles me as, if I recall correctly, NC specifically prohibits home inspectors from mentioning code in their reports, so ... why would code questions be on the home inspector test?
???? Am I remembering the NC prohibition incorrectly?
11-19-2014, 09:31 AM #3
Re: NC State Exam
Referencing code is not "prohibited" but the requirements to use code in the report is extensive, making it very impractical. The test does require knowing the codes because, as you say, codes are minimum standards. The trick is to report as not functioning as intended and being able to use code to back-up your findings, not to use the code as the defect.
11-19-2014, 09:57 AM #4
Re: NC State Exam
So, therefore it's imperative to study NC residential codes as well as the regular material. Apparently, the questions are worded in such a way that it's more difficult to choose the correct answer, as well.
The online HI courses (schools) approved by NC need to take a hard look at what these "schools" are offering-- I feel unprepared to say the least and I'm out $$$ !!?!
11-19-2014, 02:18 PM #5
Re: NC State Exam
NC has its own exam. There is a relativity small bank of questions from which it draws. There are several NC trainers that provide a Pass the Exam course. NECHS is a good provider. Instructor- owner was one of the first licensed in the state. The course teaches all the possible questions and answers for the test. His guarantee is if you don't pass, you can take his class for free until you do. There are a few questions the state wants a specific answer even though it is not the best choice. There are also questions with goofy choices. Which is an acceptable location for an open junction box?A) attic, B) crawlspace, C laundry room. NC basically adopts the IRC in whole. If you know the IRC, you know the NC Residential Code.
11-19-2014, 03:36 PM #6
Re: NC State Exam
11-19-2014, 03:44 PM #7
Re: NC State Exam
all locations are ok if done by homeowner know it all handyman--JUST ASK HIM
11-19-2014, 05:20 PM #8
Re: NC State Exam
NC uses a modified IRC and is about three years behind, we are currently using 2012 code
http://www.jjeffzehnder.com/
11-19-2014, 06:01 PM #9
Re: NC State Exam
So, the right(wrong)answer I would choose (Laundry room) based on the other areas are damp inaccessible and could cause a fire faster in those areas than the laundry room. another question you mentioned they get their questions from a "small bank" from which they draw, ok so where do other ones come from? I have 6 months to figure this out to take the exam
11-19-2014, 06:28 PM #10
Re: NC State Exam
I don't know what the test costs to take, or if there is a retake time between taking the test an additional time, but sometimes the best way to figure a test out is to:
1) take the 'no fail' class (because you get to take it again free if you don't pass)
2) take the test ... there is your sampling of questions and will give you the types of questions asked
11-19-2014, 06:53 PM #11
Re: NC State Exam
11-19-2014, 08:53 PM #12
Re: NC State Exam
The NC exam has not been updated in years. They have a small item bank of questions that are code based. I would use Code Check Complete as a good study guide. You also need to know the state law that covers home inspectors including the standards..... It is not a difficult exam... I would take a prep class if you are not sure.
11-20-2014, 03:05 PM #13
Re: NC State Exam
The NC exam has many code questions drawn from the 2009 IRC. Here is the free, online exam prep tool: Advanced Residential Code Inspection Exam Prep - InterNACHI
The code exam prep tool assumes you've already gone through this free, online home inspection exam prep tool: Ultimate State/Municipality Exam Prep course - InterNACHI at least once.
11-20-2014, 04:45 PM #14
11-20-2014, 04:48 PM #15
Re: NC State Exam
The most current ICC version available is 2012. If NC is 3 yrs behind, then it would be 2009 version. 2015 has yet been released.
11-20-2014, 07:55 PM #16
