Results 1 to 3 of 3
Thread: Gas meter wire?
    Robert Runchey's Avatar
    Robert Runchey Guest
    Default Gas meter wire?
    Can anyone tell me if gas meters should be bonded or grounded? I often see a black wire wrapped around natural gas meters coming out of the ground.
    Thank you,
    Bob Runchey
    AHI
    GEROGETOWN, KENTUCKY
    Default Re: Gas meter wire?
    Here in Ky. they wrap a wire around the pipe so they can locate later with a detector when pipe is buried. Most pipe here is yellow heavy grade pvc. The steel pipe is connected to the pvc underground.
    Thanks Mark... much appreciated.
    Bob
