Results 1 to 11 of 11
Thread: Rafter Splice - Staples
08-02-2009, 01:09 PM #1
Has anyone every seen rafter splices stapled together? I've never seen this before; I've only seen them scabbed together. It's a 1999 home and I didn't see any visible evidence of structural movement. Seems to work.
Is stapling proper? Okay? Noteworthy?
thanks,
Rob
08-02-2009, 01:28 PM #2
Re: Rafter Splice - Staples
You're not talking about trusses are you? What size rafters and stapled in what way? Did they use truss plates?
08-02-2009, 01:48 PM #3
stick framed, not truss. 2x8 rafters over a long run, so they spliced the rafters together.
The Builder used staples, not plates. Staples as in staples. Like staples for shingles, but thicker guage. A zillion of them along the splice of the butt-ends of the two rafters they spliced together.
08-02-2009, 01:58 PM #4
No.
Unless some structural engineer has signed off on that, or is willing to again if one did and there is no paperwork trail with a signed and sealed engineer's letter.
From your description, though, a simple "No." seems sufficient.
Not that photos would change the answer, but photos would sure be nice.
08-02-2009, 02:05 PM #5
08-03-2009, 08:48 AM #6
What, rafters spliced together? Are they spied end to end to create a longer span. Or are the spliced one on top of another to created a deeper rafter? An end splice can’t be done with out some sort engineering and to use staples, me thinks not. Rafters should be continuous plate to ridge.
08-03-2009, 09:03 AM #7
Nope...the spliced rafters are end-to-end to create a long run. Man I wish I had my camera!
Rob
08-03-2009, 03:44 PM #8
Man, I don't even like finger jointing, but I see it more and more. Gotta have an engineer's seal.
JLMathis
08-03-2009, 11:04 PM #9
08-04-2009, 06:50 PM #10
08-05-2009, 04:06 AM #11
It sounds like an idiot framer butt spliced the rafters and tagged the butts with a framing stapler. Typical duct-tape craftsmanship. Must be from Texas.
