Results 1 to 12 of 12
Thread: gypsum in attic
02-03-2010, 09:46 AM #1
gypsum in attic
Why would they install this here?
02-03-2010, 11:09 AM #2
Re: gypsum in attic
I saw that once a year or two ago. I didn't understand it either. Probably some type of cost saving over plywood back in the day. The stuff I saw didn't hold up very well.
02-03-2010, 11:59 AM #3
Re: gypsum in attic
What type of structure was that? I'm guessing it's not a single family residence, and it has to do with fire rating. It looks like there is plywood or OSB over the drywall, correct?
02-03-2010, 02:03 PM #4
Re: gypsum in attic
I don't ever recall seeing a 2 hour rated roof. Should have a fire damper to the vent if thats the case.
02-03-2010, 05:30 PM #5
Re: gypsum in attic
House was built sometime in the 1940s or early 1950s?
Gypsum was used for roof sheathing for a while as plywood was scarce (having been used to make boats for the war, etc.).
Fortunately that practice never lasted.
I should add: at least that is what I heard when I first saw that many years ago.
02-03-2010, 05:56 PM #6
02-04-2010, 05:30 AM #7
Re: gypsum in attic
Being from that era, are there any asbestos issues in the gypsum?
02-04-2010, 12:46 PM #8
Re: gypsum in attic
Also if the home was not within a certin range of a fire hydrant this was used to reduce Insurane cost.
02-04-2010, 01:03 PM #9
Re: gypsum in attic
02-04-2010, 06:09 PM #10
Re: gypsum in attic
Actually, if a home was not close enough to a fire hydrant the insurance would increase (there would not be a discount), and, even more important and more often missed is ... if a home was TOO CLOSE to a fire hydrant the insurance would also increase - because the firefighters would not be able to get to that hydrant and would have to go to the next further away hydrant.
I know because we had a house with a hydrant in the front yard, and there was a surcharge because the next closer hydrant was beyond the distance for the discount and that hydrant was not counted as it was TOO CLOSE.
02-04-2010, 06:40 PM #11
Re: gypsum in attic
Actually, Jerry, I think you just want to disagree with me I will expand on this. In some areas it the home is too far from a hydrant or they are not present a gyp. board underlayment will reduce Ins cost. And in multi family it can eliminate the need for thu roof parapet walls. See Attached
www.fema.gov/library/file?type...file=fs_05_roofs.txt...
02-17-2010, 06:43 AM #12
Re: gypsum in attic
Gentlemen,
This was a single family structure with a hydrant with in 500 ft. There is an addition in the back. Is it possible they buit the roof up to tie the addition roof together? There were no shingles below the ply wood. Thanks for the answers!
