Results 1 to 31 of 31
02-09-2010, 01:13 PM #1
Rafters pulling away from ridge board
What might cause these 2x12x16 rafters to separate from the ridge board?
I couldn't find any structural issues anywhere.
02-09-2010, 01:24 PM #2
Re: Rafters pulling away from ridge board
Are you sure there is movement or is it just a sloppy framing job.
Assuming framing, I would be looking for walls out of plumb, specifically pushing out at the top from rafter thrust.
Was there any rafter tie across the building from one side to the other?
02-09-2010, 01:27 PM #3
Looks like poor framing to me. See it often, cant figure out that speed square!!
James Bohac
02-09-2010, 01:42 PM #4
No collar ties installed.
Maybe they were just a lot heavier than they were used to working with.
02-09-2010, 01:52 PM #5
Looks like collar ties in the picture!
I agree with the others....sloppy cuts!
02-09-2010, 03:14 PM #6
Collar ties were recently added, and even then, not done properly.
02-09-2010, 05:11 PM #7
Sloppy cuts agreed and the ridge board is undersized.
02-10-2010, 06:41 AM #8
Ha ha..
That's what I get for trying to post from my phone..
Yes collar ties are in fact there.. Mind like a steel trap..not!
I will go with non structural. The place was built like a tank with all 2x12 framing from top to bottom and it was only a 3,100 sq ft house.. don't run into that much around here...
Thank you again for all the great info..
02-10-2010, 07:21 AM #9
RH: Actually, a ridge board is not even required in this instance. The one they have appears to be nominal 1" material which is code compliant.
R802.3 Framing details.
Rafters shall be framed to ridge board
or to each other with a gusset plate as a tie. Ridge board shall be
at least 1-inch (25 mm) nominal thickness and not less in depth
than the cut end of the rafter.At all valleys and hips there shall be
a valley or hip rafter not less than 2-inch (51 mm) nominal thickness
and not less in depth than the cut end of the rafter. Hip and
valley rafters shall be supported at the ridge by a brace to a bearing
partition or be designed to carry and distribute the specific
load at that point. Where the roof pitch is less than three units
vertical in 12 units horizontal (25-percent slope), structural
members that support rafters and ceiling joists, such as ridge
beams, hips and valleys, shall be designed as beams.
Traditional practice is to provide a ridgeboard between
opposite rafters as a nailing base and to provide a full
bearing for the rafter. Rafters must be placed directly
opposite each other, and the ridgeboard must have a
depth equal to the end of the rafter as illustrated in
Commentary Figure R802.3(1). Commentary Figure
R802.3(2) shows an option for framing opposing rafters
using a gusset plate.
02-10-2010, 07:25 AM #10
What Rick was refering to was that the ridge board is not the full depth of the rafter, which is required by code.
Last edited by Wayne Carlisle; 02-10-2010 at 07:26 AM. Reason: Said Rich instead of Rick
02-10-2010, 07:32 AM #11
02-10-2010, 07:37 AM #12
AD yep! You are correct. A ridge board is not required however when a ridge board is installed then it must be full depth of the rafters.
The reason I commented on this was because I took it that you meant that it was okay that the ridge board was undersized because the code doesn't require one.
Looks like he cut the rafters with a chain saw to me!
02-10-2010, 08:02 AM #13
02-10-2010, 08:04 AM #14
Those collar ties are practically useless being installed so close to the ridge.
02-10-2010, 08:22 AM #15
02-10-2010, 09:21 AM #16
02-10-2010, 09:33 AM #17
02-10-2010, 09:42 AM #18
02-10-2010, 09:45 AM #19
02-10-2010, 09:49 AM #20
I wasn't looking at the collar ties from a wind uplift standpoint. I was thinking about their ability to keep the rafters from spreading (ie - the rafter ties in the pic Aaron provided).
Well, I learned something new today.
02-10-2010, 09:57 AM #21
02-10-2010, 10:10 AM #22
02-10-2010, 10:30 AM #23
ad,
see post # 17 i have the greatest respect for those who work with tools and their hands for a living. i still do on occcasion when the body allows it. i have never been too arrogant to not push a broom, it comes with the territory. still use your fisher-price big boy tool set?
02-10-2010, 10:33 AM #24
02-10-2010, 11:53 AM #25
Bunch of old farts!!!!!!!!!!!!!!!!!!!!!
02-10-2010, 11:56 AM #26
02-10-2010, 12:24 PM #27
I am an older fart not an old fart like you folks. You have about 3 years on me. When I get that old then I will be an old fart. Might need a walker by then as well and will have to hire some 30 old beautiful young woman to help me up the stairs ond on the roofs and..................................Well, maybe not 30
02-10-2010, 02:04 PM #28
02-10-2010, 03:54 PM #29
ad,
blue
06-05-2011, 08:12 AM #30
06-05-2011, 11:31 AM #31
