Results 1 to 12 of 12
    Jim B. Robinson's Avatar
    Jim B. Robinson Guest
    Default Type of Insulation
    Is this a type of cellulose insulation? It's very white, feels like cotton and not irritating at all.
    Manufacturer?
    Thanks, Jim
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Type of Insulation
    Quote Originally Posted by Jim B. Robinson View Post
    Manufacturer?
    Thanks, Jim
    JR: Rock, or mineral wool. Many different manufacturers.
    Tim Hill's Avatar
    Tim Hill Guest
    To me, it looks like Insul-safe III. fiberglass
    Eric Russell's Avatar
    Eric Russell Guest
    Certainteed Insulsafe blown-in is fiberglass w/o formaldehyde. That's what I see the most of in new homes. Looks like what you've got here. Or, occassionally Knauf, which is also fiberglass. Home Depot sells a white cellulose loose fill, which also looks like this.
    Ian Niquette's Avatar
    Ian Niquette Guest
    I agree with Tim.
    Thanks guys,
    I checked out the Knauf and Certainteed websites and it looks exactly like each of those. I'm surprised its fiber glass as it feels/looks nothing like typical fiberglass products.
    Thanks guys,
    Jim,
    Roll around in it for a while and then let us know if it irritates, ok?
    Quote Originally Posted by Eric Russell View Post
    I agree, it could be white cellulose. I'd need to roll in it to be sure.
    It is coated fiberglass. The stuff is great. Get up there in the heat and have to move around in it for what ever reason and you will see that the irritation factor not only to skin but lungs is almost nil.
    A.D. Miller Guest
    TM: But, look what it has done to your mind!
    Now, that is another subject to be discussed at a later date....if I remember
    Eric Russell Guest
    Any cellulose I've seen has been a gray or dirty white color. It's usually a paper based product and now, more often than not it's recycled.
    AD mentioned that it is sometimes called "mineral wool" and one of the NACHI on-line classes refers to it as that.
