    Ian Currie's Avatar
    Ian Currie Guest
    Default Plastic Pipe in the Attic
    Any guesses as to why there's plastic PVC in the attic?
    It looks like the part that extends up on the left is over the master bedroom, the horizontal potion passes over the bathroom and the right hand section that extends up is over the kitchen.
    Ian Currie's Avatar
    Ian Currie Guest
    Default Re: Plastic Pipe in the Attic
    Here's the photo. (I thought it uploaded the first time - but apparently not).
    Orlando, FL
    That looks like ABS, not PVC.
    Does your camera have a fish-eye lens?
    James Duffin's Avatar
    James Duffin Guest
    Central vac?
    Ian Currie's Avatar
    Ian Currie Guest
    Wide angle, but not fish-eye. You must be referring to the warped timber.
    Ian Currie's Avatar
    Ian Currie Guest
    Central vac?
    Nope. No central vac in the home.
    That ABS line is sagging in the center, the is probably why Dom asked about if it was the camera - that line is not supported the way it is required to be (actually, that does not look to be supported at all).
    My only guess as to why that is run that way is that someone 'intended' to run one vent to another vent and then run that vent through the roof, but someone forgot that last part.
