Results 1 to 10 of 10
Thread: Sheathing
11-08-2010, 09:43 AM #1
Sheathing
Has any body seen this? It is inside the attic. Some kind of residue on the sheathing.
11-08-2010, 09:16 PM #2
Re: Sheathing
That could be a mould growth. It seems to be following along the dark line at the rafter as well. Hard to tell. Could it be blown-in insulation? Frost?
11-09-2010, 01:14 AM #3
Re: Sheathing
I would suspect mold growth - though it doesn't appear to be particularly widespread. Does it show on the other side of the rafter? Could be the sheathing was installed wet, or got wet before any roofing membrane was installed. Any moisture may have been trapped and perhaps drawn inside. Of course there could also be an active leak somewhere. How old is the roofing system?
11-09-2010, 04:32 AM #4
11-09-2010, 08:06 AM #5
Re: Sheathing
This seems right to me, though maybe not from a leak. It could've just been bad storage at warehouse or on site. The way the sheathing is all furry it looks like it may have been extremely wet once, allowing the beginning mold growth, then quickly dried out after installation, killing the mold.
Of course, I could be wrong.
11-09-2010, 10:01 AM #6
11-09-2010, 09:03 PM #7
Re: Sheathing
Maybe FRT plywood?
Is the sheathing delaminated at all, and is it original?
Reason I ask is that I don't see moisture stains around the exposed nails, nor do I see much in the way of corrosion on the nails, which leads me to rule out the mold idea, but it's tough to tell from the pictures.
11-12-2010, 03:40 PM #8
Re: Sheathing
It certainly seems to be fungal / mold growth to me which looks newer than the 1987 date. Perhaps the roof leaked elswhere than above that particular unit and migrated to the area now observed. Were you able to physically check the integrity of the roof itself? Any signs of repair or existing defect?
11-12-2010, 04:31 PM #9
11-12-2010, 07:34 PM #10
Re: Sheathing
I'm guessing you're seeing some evidence of past or present gypsum board or layer plus moisture and heat non-"exposure" side.
What's on the other side of this plywood, exactly, layers (note minimal nail penetration). Proximity to common wall, parapet, etc. what is where?
Suspect fire rated assembly.
