Results 1 to 14 of 14
    Don Martin's Avatar
    Don Martin Guest
    Default Messure once, cut......
    Posted without comment
    Healdsburg, CA
    Default Re: Messure once, cut......
    Ahhhh...... but those rafters where only cut short on one end!
    New York
    Yes, but which end?
    homeinspectionsnewyork.com
    eifsinspectionsnewyork.com
    Check out these beauties from yesterday's inspection.
    Stephen G's Avatar
    Stephen G Guest
    Was it a realy old modular home, those rafter cuts look they might have hinged and then a knee wall was added...?
    Quote Originally Posted by Stephen G View Post
    Nope. Less than 20 year old townhome.
    Knoxville, TN
    They should have got some board stretchers
    Healdsburg, CA
    The builder is a gormet cook and wanted to make raftercheek soup.
    (he is also an idiot)
    Some of those rafters had maybe 20% bearing surface support.
    Apr 2007
    WESTMINSTER CO
    our city inspectors at there best
    --city drive by inspection
    cvf
    It is a manufactured truss roof with a hip at the end. The truss on the left is truncated to fit the hip. The 2X4's coming down from the peak and hip ridges would actually be laid flat in most cases where the builders followed the plan. The actual weight carried by those 2X4's is not that great, but they need to rest firmly on the top chord of the truss.
    I use to hear all of the time,
    "I've cut it tree times and it's still to short. What's wrong with this lumber?"
    Edward Olsoe's Avatar
    Edward Olsoe Guest
    That's a great one Garry. Thank you, I'm gonna use it!
    May 2010
    St. George, UT
    Or....
    How long do want this 2x4?
    Quite a while, I'm building a house with it!
