    Lisa Simkins's Avatar
    Lisa Simkins Guest
    Default What type of insulation is this?
    Hi:
    My guess is blown in cellulose but it looks different than the cellulose I've seen before. Maybe some kind of fiberglass?
    Also, does fiberglass come in yellow batt or only pink batt? How do you tell mineral rock batt from fiberglass - colour only?
    Default Re: What type of insulation is this?
    Quote Originally Posted by Lisa Simkins View Post
    Hi:
    Looks like blown fiberglass (with dust)
    Batts can be any color
    Common colors are pink, yellow, and white
    Pink batts are Owens Corning
    NoCal
    Hi Lisa
    That looks like 'Insul-safe' type of blown in insulation. Probably had a roof change - with all the debris that's laying on it.
    The mineral wool generally is a gray colored fiberglass insulation - the nasty stuff we hate to crawl through - gets into every pore.
    The insul-safe stuff is a non-binder and generally does not cause the itchiness.
    Aug 2010
    BC Canada
    few builders put mineral wool on attic
    NoCal
    I agree Peter, not anymore. Modern materials are far superior to work with than that old stuff. But I find it occasionally in older homes in attics.
    Mar 2011
    Sparks,NV
    Looks like blown fiberglass to me. Batts can come in white, yellow, or pink.
    Nevada IOS#1730
    Nevada Energy Auditor #30
    775-342-4767 www.homecsi.com
    Zane Remenda's Avatar
    Zane Remenda Guest
