Thread: What is this?
06-15-2012, 10:25 AM #1
06-15-2012, 10:52 AM #2
Re: What is this?
They are foam baffles, designed to keep the insulation from blocking the soffit vents. Ideally they should be fastened to the roof truss to hold them in place.
Welmoed Sisson
Inspections by Bob, LLC, Boyds, MD
"Given sufficient thrust, pigs fly just fine."
06-15-2012, 10:54 AM #3
Re: What is this?
Thanks for the fast reply. Learn something new every day
06-15-2012, 11:09 AM #4
Re: What is this?
They are installed prior to the installer blowing the insulation. These do not appear to be far enough up the rake of the rafters to do much good. The installer probably blew insulation over and into the soffit making the area clogged and preventing air circulation...which these apparatusses were supposed are supposed to prevent.
It looks like they may have cut them into thirds to save money because usually they are usually 4 to 5 feet in length.
06-15-2012, 12:23 PM #5
Re: What is this?
06-15-2012, 02:59 PM #6
Re: What is this?
06-15-2012, 06:25 PM #7
Re: What is this?
Donald - Here's a diagram showing how their placed in the attic venting system.
06-18-2012, 05:42 AM #8
Re: What is this?
Robert,
I agree with everyone else have said. I would suggest you make client aware so
they may have them correctly place and secured so they can fully serve their purpose.
Thanks.
Mike Rodney
Ontario, Canada
