Results 1 to 20 of 20
Thread: Insulation is Overrated
01-22-2014, 10:25 AM #1
01-22-2014, 10:51 AM #2
Re: Insulation is Overrated
Where are the cardboard rulers? Yeah, they needs sum mo skooln"
01-22-2014, 10:59 AM #3
Yep, none of those up in the attic. Bruce.
01-22-2014, 11:32 AM #4
I've seen a couple of newer construction houses like that. If you just poked your head up in the hatch you could see big fluffy piles of insulation surrounding the opening but when you actually crawled up in there the insulation just tapered off to barely nothing. I'm guessing it was the builders savings plan.
Galen L. Beasley
Inspections Supervisor
Housing Authority of Kansas City MO
01-22-2014, 11:33 AM #5
I don't see any baffles installed around the perimeter. Likely means that there are no baffles around the attic access opening either.
01-22-2014, 12:18 PM #6
Do you mean the soffit baffles Jerry? Some are there and some are not and some that are there are filled with insulation.
01-22-2014, 01:25 PM #7
Yes, but not just at the soffits, also along exterior walls at porches and where the living space thermal envelope is adjacent to garages, also around attic access openings.
The baffles need to be at least as high as the minimum depth of the insulation to keep the insulation to at least the minimum required depth before spilling over ... or they can insulate far enough beyond the thermal envelope perimeter that the insulation at that perimeter will not fall over to where the insulation does not meet the minimum required depth.
01-22-2014, 04:33 PM #8
Nick,
To clarify my previous post (quoted above), the baffles I am referring to for the soffits are not the ones shown in your photo, those would need to be installed from truss-to-truss all along the soffits without leaving any space for the insulation to fall through. Those baffles are typically used for batt insulation and compress the batt insulation down to open the area above the vent for air flow.
The ones I am referring to are here: Baffles, Panels & Blocks - right column 1st one, 4th and 5th ones down, left column 4th and 5th ones down. One could also install one of the baffles which simply gets attached to the bottom face of the truss or rafter.
These create a dam which holds the insulation back. The ones shown in your photo, while used for loose fill insulation, are not much good unless the entire bay between trusses/rafters is protected with the baffles to keep the loos fill insulation from falling into the soffits.
01-23-2014, 07:40 AM #9
01-27-2014, 09:25 AM #10
I can go one better on a new house ready for closing. NO insulation at all in the attic. No one every even looked in the attic after drywall went up including the county inspector.
Stu, Fredericksburg VA
01-27-2014, 09:58 AM #11
Nice find, Stuart. Somebody gets a cuff to the head for that. The builder leaves it up to the subs, the boss sub sends the crew on to the next house, the crew just show up and go where the boss sends them.
Oh, yeah, the inspector for the county? He drives a sedan, no ladder.
I had a new house recently with 3 attic hatches, complicated roofline. Hatch 1 and 2, yep plenty of nice insulation. Hatch 3 above the master bedroom? Nope, guess they missed a hatch.
01-27-2014, 10:05 AM #12
01-27-2014, 11:03 AM #13
County inspector does not need a ladder - contractor needs to provide access, which includes having an OSHA approved ladder there.
I carry a small Little Giant-type ladder in the vehicle, barely reaches the edge of a low single story roof - any higher than that and the contractor provides the ladder.
At the apartment complex I am inspecting now (almost every day of the week from last October to this coming November (anticipated finish) I have one of the contractors take me up in a lift (3 story buildings) ... and, yes, I wear a safety harness.
01-27-2014, 02:05 PM #14
I see this on new construction around my way quite often. Some AHJ wants it left out until they have done there inspection and allot of times it's right up to the closing dates. "Why" I don't know but I will ask the next time I see one. I bet if you asked the builder he would of told you something along those lines.
01-27-2014, 02:11 PM #15
01-27-2014, 05:38 PM #16
01-28-2014, 10:08 AM #17
As others have stated, this is no surprise. I my areas large builder typically build to a different schedule than the codes were set up to deal with and they will work out of order or in an order that works for their work flow and pay for re inspections when they fail items. The difference is they will fail the insulation inspection before the drywall was placed but the failure would note the specifics (this would create a record) and they would pay for a reinspect after the ceilings were installed so they can use blow in insulation in those areas. It is still up the the AHJ to do the inspection and sometimes they miss it. IT is a concern that they would sign off on it without looking!
http://www.jjeffzehnder.com/
01-28-2014, 11:20 AM #18
All the more reason why we as inspectors need to walk every attic interior we can. If I did an inspection from the hatch alone and didn't actually enter the attic, I wouldn't have been able to see most if not all of this. I'll squish a little insulation every time as a trade off to make sure I find stuff like this.
01-29-2014, 12:08 PM #19
Seems like there will always be some conflict between "readily accessible" and getting the job done properly. My son and I have both damaged ceilings by tripping over concealed wiring or plumbing vents in attics. Luckily only egos hurt but it does make you more cautious about the attics you walk.
Another place where thermography can/will help. With the proper equipment you can now get a feeling for the insulation adequacy and distribution from the rooms beneath it. It doesn't eliminate the need for viewing the attic but does help with areas riskier to access directly.
I really don't like falling through ceilings, but that's just me.
01-29-2014, 03:13 PM #20
My client didn't want to fall through this ceiling but that didn't stop him.
http://www.inspectionnews.net/home_i...h-ceiling.html
