Thread: Odor in attic
11-02-2007, 01:39 PM #1
Odor in attic
11-02-2007, 01:43 PM #2
Re: Odor in attic
Robert,
Who would you think is a "appropriate" contractor?
I would just comment that a unknown odor was present in the attic and leave it at that.
Could be a dead rodent or some type of vermin urinating in the attic space.
I would not call it out as mildew unless I actually could see it.
JMHO
11-02-2007, 02:40 PM #3
11-02-2007, 02:54 PM #4
Re: Odor in attic
"It smells like something rotten (or whatever) in the attic and I don't know what it is."
11-02-2007, 04:22 PM #5
Re: Odor in attic
Robert,
See all those white things hanging down? Those are fungi (at least that's what they look like to me in those photos), and that is likely what you smelled.
I would add: Remove *new* roof covering, replace rotted roof decking, *replaced* roof covering ... again ... cleaning up the attic of any decaying material when the roof sheathing is off for replacement.
11-02-2007, 05:32 PM #6
Re: Odor in attic
NO, I don't think so myself that we should tell them how to get rid of an odor. If you don't what is causing the odor, how can you make a call on how to handle it. Masking an odor is not getting rid of the source.
Now that Robert has posted some pic's after the fact, I would make note that the roof decking has water damages and it should be replaced.
JMHO
11-02-2007, 06:35 PM #7
Re: Odor in attic
Robert,
If I smell a "musty" odor, I report it as a "musty" odor, state that it indicates an excessive moisture condition and that I am not qualified to test for mold or mildew. The source of moisture needs to be located and controlled/eliminated.
However, the stuff in your pics... Well, I would certainly talk about that. And, not just as a "musty" odor. That is certainly a problem that you can see. Could be caused by inadequate ventilation, roof leaks or both. (I think both)
