    Default CSST bonded to black iron pipe
    Is CSST considered bonded if it is an extension of the existing black iron gas piping system or must it be separately bonded?
    Default Re: CSST bonded to black iron pipe
    Quote Originally Posted by Don Hawley View Post
    To my understanding, ALL CSST is required to be bonded with a bonding jumper to the GEC system with the appropriate heavy copper wire and clamp attached to the black iron pipe, etc. (not the CSST itself)
    incidental bonding through the equipment ground of attached systems is not enough.
    A foot or a mile triggers the same requirement.
    This spells it out pretty good.
    http://www.csstsafety.com/Images/CSS...h-Bulletin.pdf
    This addresses bonding of CSST: http://jerrypeck.com/IFCN/2015-11%20...-11%20IFCN.pdf
    The code reference is the Florida Building Code, but it is likely the same as or similar to the code for your area as the Florida codes are based on the ICC codes.
Tags for this Thread
