Results 1 to 11 of 11
Thread: Truss Rafter repair?
12-03-2007, 04:39 PM #1
12-03-2007, 05:03 PM #2
Re: Truss Rafter repair?
Looks like someone decided to add their version of a stiffback. However, why they would do it with (presumably) engineered trusses is beyond me.
12-03-2007, 06:26 PM #3
Was there a wall under that area?
Maybe soffit with cabinets?
12-03-2007, 07:00 PM #4
12-03-2007, 07:29 PM #5
That would be one hell of a long, straight soffitt! Assuming 24" spacing, that's at least 12' visible and likely more that we can't see. If we assume that they only hung 2X4 blocks and reinforced the bottom chords where the soffitt was to be installed that would be an atypical bath layout. I don't think I've ever seen a 12' long bath vanity...with or without a soffitt above. I suspect something else. My guess is that some carpenter who didn't understand trusses, at whatever time and for whatever reason, thought reinforcement was necessary. Possibly due to a remodel where interior walls were removed; possibly not. In any case, I see no harm done based on the information given that there were no other signs of distress inside. The bottom chords need to be tied together anyway; think of this as an overly elaborate way of doing it since normally there's just a 2X4 "rat run" installed.
12-03-2007, 08:16 PM #6
I agree with Jerry. Someone built a box to hide a pipe or a duct.
12-03-2007, 08:53 PM #7
Almost any duct or pipe could have been run through the attic. No need to go through the trouble and expense of building a soffitt to hide them. And, if you roughly scale the photo, it makes it unlikely that the soffitt would have been wider inside than about 10" max. Pretty narrow for any kind of soffitt.
I still say it's an attempt -- needed or not -- at structural stiffening.
12-03-2007, 08:57 PM #8
This may have been an attempt at creating a slip joint for a non-bearing interior wall to avoid up-lift... just brain storming here.
The key is what is below in the interior.
In any case, I do not see anything cuts on the trusses that would be a problem.
12-04-2007, 06:13 AM #9
I agree on those, but ...
I might go with the 'structural stiffening' if there were no vertical pieces, then I would consider the laterals-on-edge as lateral braces, but here, I think those are just to set as supports to nail the verticals to.
As Jim said, I don't see anything which looks like it is a problem, and, in fact, if there was a soffit there and it is now gone, that is good as that removed weight hanging from the trusses which (I am sure) was not included in the truss loading design.
12-04-2007, 07:19 AM #10
You're right about the width. For some reason I had a brain failure and was looking at the width to the outside of the 2x6's, not the vertical 2x4's.
12-04-2007, 07:30 AM #11
