Results 1 to 13 of 13
Thread: Self closing door
02-10-2017, 11:07 PM #1
Self closing door
Is Self closing door required in the private houses? They are pretty dangerous for residents - especially for elderly, especially with osteoarthritis or other medical issues when a person needs longer time to pass the door.
Does anyone know how I can help people with it to allowed them to use a regular door instead of self closing door.
I know it need to be self closing to for fire prevention - but how often is it? but an elderly person can hurt himself every day by using such door! t should make some common sense.
Any one can advise or comment?
02-11-2017, 06:46 AM #2
Re: Self closing door
A self-closing door is only required between the garage and the living space, no other door is required to be self-closing ... in a one- and two-family dwelling or in townhouses.
In apartments and condos, the door(s) which open to a common area need to be self-closing as that is part of the rating for rated doors.
A person who requires more time could install a regular door closer instead of spring hinges, or they could install an electric opener where they push a button to open the door - those give even more time before self-closing.
02-11-2017, 08:09 AM #3
Thank you so much for your response- excellent ,as always.
Yes , it is only one door - but it is the most popular door for this family. I want to help them. They will have a real problem with this " self closing door " . To add difficulties - this door goes to the garage and then it does have steps down ! So , it is a real problem for them.
However , they told me that inspector requested to make it as " self closing " as per code ( it was what he said ). This family asked my advise - how they can skip it andleave it as a normal regular door.
We all respect the code - but this self closing door does not fit every family. It could potentially be very harmful , as an example for this family of elderly with advanced osteoarthritis.
Any advise I could give this family to help then to pass final inspection without this " self closing door" ?
02-11-2017, 09:38 AM #4
IF the door swings into the garage (unlikely and not often done, but this is done at times) then a landing on the garage side is required, as wide as the door is wide and as deep in the direction of travel as the stair is wide, 3 feet minimum.
IF the door swings into the living space (which is most common), then the landing is inside the living space and the landing is not required at the garage because there is an exception for that, however, nothing prohibits installing a landing on the garage side (if there is space for the landing).
- Residential Automatic Door Opener - Model 2300 - Residential Handicap Door Opener - Power Access Corporation
The residential codes require self-closing, this should address that issue quite well and be acceptable to all parties.
02-11-2017, 03:45 PM #5
While self closing doors were very common in CA, they are pretty much non existent in my part of TN. The AHJ don't seem to care about this part of the code.
02-11-2017, 10:14 PM #6
Why not either adjust the closer that is there at present or change out the closer to one that is adjustable.
04-22-2017, 08:34 AM #7
2014 Florida Residential Code 302.5.1 requires the door from attached garage to home must be a 'self-closing' door.
05-12-2017, 03:49 AM #8
05-12-2017, 06:32 AM #9
I saw this one earlier in the year but got busy. Am I missing the part where the self closing is required? I thought that was removed from the 2009 IRC, or earlier? I just read 302.5.1 again, and there is no mention of a self closing device. The 20 minute, etc. is there, but nothing about a closer.
I do know some states have kept it in place, including mine, via a list of state code amendments, along with the 5/8 Type X for the common wall, but I do not see it in the general IRC. Is it listed somewhere else in the 2009 IRC?
05-13-2017, 01:36 PM #10
It was omitted in 2009 IRC but is back in 2012 IRC and is included in 2015 IRC.
R302.5.1 Opening protection.
Openings from a private garage directly into a room used for sleeping purposes shall not be permitted. Other openings between the garage and residence shall be equipped with solid wood doors not less than 1 3/8 inches (35 mm) in thickness, solid or honeycomb-core steel doors not less than 1 3/8 inches (35 mm) thick, or 20- minute fire-rated doors, equipped with a self-closing device.
05-14-2017, 09:54 AM #11
Got it, thanks. We haven't moved past 2009 code cycle yet locally.
05-18-2017, 10:12 AM #12
A self closing door is required between an attached garage and residence but I don't know of any other requirement...The hinges with an integral closer seems to be less forceful (and adjustable) than the commercial type closer. Good Luck
Gary V.
AIA, Building Official
- - - Updated - - -
Gary V.
06-02-2017, 09:31 AM #13
