Thread: SPF insulation
01-30-2008, 03:47 PM #1
SPF insulation
I don't see this stuff much at all and have a question. Does this spray foam insulation blown onto the underside of the roof framing require a fire retardant coating be sprayed over it?
And no, that is not a flue, it is a fresh air intake for the ventilation system.
Similar Threads:If it weren't for lawyers, we would never need them.
01-30-2008, 04:54 PM #2
Re: SPF insulation
01-30-2008, 05:46 PM #3
Re: SPF insulation
Ok, waiting for the other shoe to drop.
When all JP has to say is "No", you have to wonder.
Hey, I just realized what the three dots are for - minimum 5 characters!
Anyway, this has been discussed fairly recently - if you search the forum for "attic foam insulation" without the quotes, I think you'll find some useful info.
01-30-2008, 07:23 PM #4
Re: SPF insulation
05-25-2008, 07:12 AM #5
Re: SPF insulation
I know this an old thread and I am a new guy to this forum. However, the correct answer is "probably no". Based on fire safety testing a few brands require the barrier.
05-25-2008, 05:09 PM #6
Re: SPF insulation
