Results 1 to 12 of 12
    Jim Dull's Avatar
    Jim Dull Guest
    Default Lots of Insulation
    How do you inspect an attic when it is this full of insulation?
    Jim Dull's Avatar
    Jim Dull Guest
    Default Re: Lots of Insulation
    Sorry. Forgot the pic
    All you can do Jim is look at what you can see and get to and disclaim the rest. I know some guys will not walk in an attic that has the floor covered with insulation and has no floor decking but if you take your time and feel for the joists with your feet, you can make your way around in the attic. You just can't see everything.
    Jim Dull's Avatar
    Jim Dull Guest
    Thanks Nick. Yeah, I agree. I will always feel my way around if possible but this one wasn't.
    Patrick Norton's Avatar
    Patrick Norton Guest
    Jim, I will climb in the trusses or framing as much as I can but I don't disturb the insulation levels where not already disturbed.
    I won't step on a truss or joist where I can't 'wiggle' the insulation away with my foot and see or feel wood. Too many mechanicals to step on, damage and/or be hurt by. A lot depends on the pitch of the roof. If I can basically stand up I'll make a run down the middle. Something like that picture? No way... I look from about the point where you took the picture.
    Quote Originally Posted by Jim Dull View Post
    "Attic was viewed from the access hatch. Attic was not entered due to restricted clearance, insulation covering joists and the possibility of damaging finished ceilings. Client is advised that inspection of this area was limited."
    Either that or you swim through. Personally, I like getting insulation in all of my orifices.
    That being said, I still make an effort whenever possible to get to the areas around the heating flue pipes and other roof penetrations to look for evidence of leaks. If there is a type B flue vent running through the attic, chances are pretty good that there will be something in contact with the pipe that shouldn't be like piled up insulation. It's also good to push back the insulation around the flue pipe and make sure the penetration is firestopped.
    Thats not really a problem.
    You just take one of those gas powered lawn blowers and start working towards the rear of the attic.
    When you make it to the end of the attic, you reverse the process but try to keep the insulation from blowing back through the attic opening.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    "Float like a butterfly"
    I will not enter an attic space in which the tops of the joists are covered with insulation. Even though I can probably wiggle my foot around and find solid footing, the insulation is compressed or otherwise disturbed by walking on it, thereby reducing its insulation properties and damaging the insulation "system". My inspections do no damage. I report and disclaim.
    Tennessee
    I felt around with my foot once too.....and ended up with one leg in the bedroom below me.
    Price of inspection: $275
    Price for repairs: $480
    Lesson: "limited evaluation"
