06-25-2008, 08:09 PM #1
Name for this OLD loose insulation?
Found this in the attic of a 140 year old house. Combination of wood shavings, vermiculite (if it can be white), and some hard bits of stuff which looks like plaster mud or stone/mineral. Is there a name for this mixture, or is it just some random by-product?
Thanks,
06-25-2008, 09:30 PM #2
Re: Name for this OLD loose insulation?
Peter,
You run into some weird stuff! I would say it is a composite of vermiculite and wood shavings and be done with it. Probably not enough insulation anyway.
06-26-2008, 03:45 AM #3
Possibly asbestos containing material.
06-26-2008, 07:03 AM #4
Peter,
I would simply describe it as you did, then add Gunnar's and Jon's comments:
Attic Insulation:
Pretty much describes it, advises it is likely not of much use, and warns as to what *it might* contain.
The only other thing I would add is "Potentially a fire hazard." When talking with your client, if you tested it to see if it ignites, you could say 'Makes good kindling for starting fires. I tested some outside, want to see it go up in flames?'
Did you try to ignite some (not in the attic, of course, but outside)?
06-26-2008, 07:04 AM #5
Agree with Gunnar, looks like vermiculite with other stuff. Tell the client to have it tested. They can put some in a baggie and send it off to a lab. Costs about 50-75 bucks around here.
06-26-2008, 07:07 PM #6
