Results 1 to 10 of 10
    Stephen G Sheldon's Avatar
    Stephen G Sheldon Guest
    Default Protrusion from roof
    Does anyone know what that could be sticking out of the roof between the plumbing vent and the roof vent?
    Default Re: Protrusion from roof
    Central vac exhaust?
    Looks like a roof anchor/ tie off point (called a "super anchor" in my area). If that is the case, it may be missing the plastic/ rubber cap that is needed to prevent leakage (I can't tell if I see metal or plastic at the top).........not that I've seen ones with a missing cap actually leak.
    When you were in the attic, you would have seen 2 metal brackets run through the sheathing. They should have been fastened to either side of the rafter/ truss chord. (if I am correct on what it is)
    Evan Grugett's Avatar
    Evan Grugett Guest
    It appears to be a 3" or a 4" PVC pipe, too large for a central vac exhaust (usually 2"). In my area the central vac exhaust never comes through the roof. It exits near the bottom of the building. The house is too new for the pipe to be an overflow from an old gravity HW heating system tank in the attic. Check the attic for the bottom side of the penetration, that may shed some light on this.
    As suggested in another thread on the same topic, it could be some type of antennae. The picture is not revealing enough.
    Anacortes, Washington
    It appears to be the Osha required tie-off. These tie-offs typically have a black plastic hood that goes over them. If you look in the attic you will see a U-bolt going over a rafter and an additional 2x4 sistered to the rafter. Is this is in a housing tract every home will have at least one.
    //Rick
    Rick Bunzel
    WWW.PacCrestInspections.com
    360-588-6956
    It does make it confusing to have two threads on the same topic, by the same person, one day apart. Means having to look in both places for information.
    I'm going with the OSHA tie-offs.
    Never seen a tie-off which is standing. Up here the tie-off is a nylon strap wrapped around rafter and exterior portion just has an O-ring tie off on the nylon strap. Must be a regional difference.
    Fuquay Varina, NC
    They are flat stainless steel with an eyelet. They are 2 piece sandwich together and tack welded along the edge. The plastic cap is to keep it from leaking along the seam. There is a rubber boot and the plastic cap is zip stripped to the rubber boot.
    Super Anchor Fall Protection Page 1
    Mike Schulz License 393
    Affordable Home Inspections
    www.houseinspections.com
    Brent Simmerman's Avatar
    Brent Simmerman Guest
    Some newer homes around here have PSD (passive soil depressurization) system for Radon. That will be a 3 or 4 inch PVC pipe protruding from the roof.
