Old 05-15-2007, 07:38 PM
John Stephenson
Posts: n/a
Roof sagging?
Maybe hard to tell in photo, but do you thing this type of sagging warrants repair? I didn't see any "obvious" issues with the truss framing. (1983 home on slab foundation)
HomeGauge Reports
Old 05-15-2007, 07:56 PM
wayne soper's Avatar
Re: Roof sagging?
This is partially caused by the doubled shingles or Ice dam retarder at roof edges. No, repairs are not required, unless excessive deflection is noted at the roof rafters. Meaning, if rafters were set crown down and all are sagging indicating poor framing practices then, installation of a knee wall at attic would be recommended.
How old is the home. If 20+ years the framing would not comply with today's standards but if holding loads properly there is not a problem.
Did you walk on it. Was there bounce in the structure. Were you afraid for your life. If yes, there is a problem. If No, Typical 1970's roof framing.
Old 05-15-2007, 08:14 PM
John Stephenson
Posts: n/a
Re: Roof sagging?
Ha! Too funny, Wayne.
Yes, I walked on the roof! No "bounce" in decking.
I was only afraid of the 5 squirrels that kept running around on the roof!
Old 05-18-2007, 12:54 PM
Frank Kunselman Frank Kunselman is offline
Re: Roof sagging?
Truss Roof you say. That sure looks like a ridge cap and a 4 to 5 foot span of sag at the ridge. I've never seen the gusseted ridge of a truss sag like that before...trusses are 24' oc aren't they?
Are these scissor trusses? If the span of the sag is 4 ft or more you might want to investigate further...broken truss maybe???
Old 05-18-2007, 06:39 PM
Jerry Peck's Avatar
Re: Roof sagging?
A lot of time the trusses are set in proper alignment with each other, or are (what! how can that be? ) not all made where they are in proper alignment with each other when set.
Set one or two trusses back just a little from the ones on either side and there 'will appear to be' (because 'there is') a dip in the roof right there.
*IF* the trusses are built correctly, you will see a matching raised ridge on the back of the roof where the dip is on the front. However, if the trusses are 'not quite right' in size, the back roof slope could very well be (likely is) flat and in plane.
You would be surprised how well that telegraphs through the roof covering even when the roof covering is tile.
  #6 (permalink)
Old 05-19-2007, 04:31 PM
Eric Barker's Avatar
Eric Barker Eric Barker is offline
Re: Roof sagging?
I will sometimes have homes where at one end of the attic they run the ceiling joists parallel to the ridge (attached). The rest of the joists are perpendicular to the ridge.
Eric Barker
Barrington, IL
Similar Threads
Roof Type David Banks Roofing System: Home Inspection and Commercial Inspection 5 05-01-2007 05:49 AM
Metal roof Frank Bombardiere Roofing System: Home Inspection and Commercial Inspection 3 04-26-2007 04:09 AM
Roof flashing william siegel Roofing System: Home Inspection and Commercial Inspection 2 04-18-2007 03:50 PM
Roof decking Jeff Eastman Roofing System: Home Inspection and Commercial Inspection 3 04-15-2007 09:01 AM
What Kind of Roof Covering is This? Nick Ostrowski Roofing System: Home Inspection and Commercial Inspection 9 04-12-2007 04:39 PM
vB.Sponsors
Ad Management by RedTyger
