Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
Old 07-02-2009, 03:24 PM
Patrick McCaffery Patrick McCaffery is offline
Sump Pump Piping
Last night I inspected a Townhouse and while testing the sump pump I noticed that it was backing up into the laundry tub. The laundry tub is in between the sump pump and the line outside. Past the Laundry tub the piping sags due to lack of hangers. I feel that water is laying in the low part of the pipe and the sump pump has a hard time pushing the water.
Is there supposed to be anything connected between the sump pump and the disharge to the storm sewer?
IC Home Inspection Report Writing
Old 07-02-2009, 05:00 PM
Re: Sump Pump Piping
As far as I know, nothing is supposed to be tied to the out side of the sump pump. Since the discharge is pressurized it will go somewhere else if it can. Straight outside or to an inverted sewer connection. I'm sure one of the PL Code guys will have a reference soon. Good luck
Old 07-02-2009, 05:34 PM
Thank you Markus,
That was my take on it. I checked the code books and it was somewhat vague.
Old 07-05-2009, 11:46 PM
JORY LANNES JORY LANNES is offline
I have see sump pumps installed in pump wells sitting on the basement floor attached to a slop sink to discharge gray water from the washing macine. THe discharge usually goes out a window pane that has been replaced with plywood. THe vegitation is usually dead. THe home owner is usually proud of his "SETUP"
BETTER THAN DUCK TAPE AND CAULK
Jory Lannes
Lannes Group Inspections Inc. Chicago, Il.
847 733 7705 jory@lannesgroup.com
Old 07-06-2009, 07:39 AM
Jerry Peck's Avatar
Quote:
The IRC does not address sump pumps very well. The IPC does and the definitions is the key to what the following says.
From the 2006 IPC. (red, underlining and bold are mine)
- 712.3.5 Ejector connection to the drainage system. Pumps connected to the drainage system shall connect to the building sewer or shall connect to a wye fitting in the building drain a minimum of 10 feet (3048 mm) from the base of any soil stack, waste stack or fixture drain. Where the discharge line connects into horizontal drainage piping, the connector shall be made through a wye fitting into the top of the drainage piping.
- BUILDING SEWER. That part of the drainage system that extends from the end of the building drain and conveys the discharge to a public sewer, private sewer, individual sewage disposal system or other point of disposal.
- - Combined. A building sewer that conveys both sewage and storm water or other drainage.
- - Sanitary. A building sewer that conveys sewage only.
- - Storm. A building sewer that conveys storm water or other drainage, but not sewage.
- BUILDING DRAIN. That part of the lowest piping of a drainage system that receives the discharge from soil, waste and other drainage pipes inside and that extends 30 inches (762 mm) in developed length of pipe beyond the exterior walls of the building and conveys the drainage to the building sewer.
- - Combined. A building drain that conveys both sewage and storm water or other drainage.
- - Sanitary. A building drain that conveys sewage only.
- - Storm. A building drain that conveys storm water or other drainage, but not sewage.
  #6 (permalink)
Old 07-06-2009, 08:19 AM
Thanks Jerry;
You are a fountain of information. I appraicate the update.
Jory Lannes
Home Inspector Essentials. The BEST prices for inspection tools.
Similar Threads
sump pump on gfci outlet CHARLIE VAN FLEET Plumbing System: Home Inspection and Commercial Inspection 4 04-22-2009 01:51 PM
Sump Pump odors? Bruce Ramsey Plumbing System: Home Inspection and Commercial Inspection 6 08-28-2008 09:55 PM
Sump pump installation mathew stouffer Plumbing System: Home Inspection and Commercial Inspection 7 07-22-2008 12:00 AM
Outdoor sump pump GFI? Matt Fellman Electrical Systems: Home Inspection and Commercial Inspection 2 07-10-2008 02:28 PM
Here's where you plug in the sump pump Eric Laney Electrical Systems: Home Inspection and Commercial Inspection 1 04-25-2008 05:21 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
