Old 06-11-2007, 07:49 AM
Greg Jenkins Greg Jenkins is offline
Valley rafter gusset
Here is a picture of a valley rafter with an OSB gusset. Is a gusset acceptable in this area and if so, is OSB appropriate for this application or should the gusset be made of plywood?
Greg Jenkins
Old 06-11-2007, 08:08 AM
Jerry McCarthy's Avatar
Re: Valley rafter gusset
No like! However, if they had installed a 2X support post under the valley rafter joint along with a gusset plate, I'd have bought that.
Construction Consultant
Old 06-11-2007, 08:36 AM
Tony Mount Tony Mount is online now
How do you post a new message on here?
Old 06-11-2007, 12:21 PM
Thom Walker's Avatar
Greg,
That gusset you're looking at is commonly referred to as a scab. The rafter has been spliced. If it's going to be there, it should have scabs on both sides and a brace to bearing beneath, as close to the splice as possible. The scabs should extend minimum 2 feet beyond the splice on both sides of the splice.
I do not find the method discussed in IRC. Someone else might. However, I have seen it in the former Texas windstorm code and I have seen it employed in many municipalities. I've seen the technique used in engineered framing. I write it up when any of the components I mentioned are missing. Otherwise, I note the number and locations of the splices and whether or not I see any visible evidence of failure as a result.
- Paul Fix
Similar Threads
rafter issue John Stephenson Attic Areas: Home Inspection and Commercial Inspection 5 06-02-2007 01:09 PM
rafter shims wes owens Attic Areas: Home Inspection and Commercial Inspection 9 05-27-2007 11:11 PM
Rafter splicing Richard Rushing Attic Areas: Home Inspection and Commercial Inspection 15 05-16-2007 05:31 AM
Mesa jump-starts pool safety - East Valley Tribune Brian Hannigan Pool and Spa: Home Inspection and Commercial Inspection 0 04-21-2007 11:11 AM
Rafter nailing william siegel Attic Areas: Home Inspection and Commercial Inspection 8 04-17-2007 11:29 AM
vB.Sponsors
Ad Management by RedTyger
