Old 10-15-2009, 10:20 PM
Barry Lewis Barry Lewis is offline
Funky insulation!
Any idea as to the type of insulation and the maker of this stuff? First time I've ever seen it. Looks like sawdust wrapped in a plastic bag. House was built in 1958.
Home inspection - The Cost Of Business.
Old 10-15-2009, 10:55 PM
Re: Funky insulation!
It's hard to tell from the picture. It looks like wool (likely mixed with asbestos if it's from 1958) with a tar paper-ish vapor barrier/retarder. I've seen similar stuff before. What I can't tell too well from the picture is how loose the material is.
www.crawfordinspections.com
Old 10-16-2009, 05:48 AM
Quote:
Thanks Matt. You're probably right. The outside wrap looked and felt similar to vinyl while the inside resembled tar paper. The particulate inside was powdery, light and felt almost like sawdust. It appears to have come in totally encapsulated sleeves. Does that sound like the stuff you're familiar with?
Old 10-16-2009, 06:37 AM
Roger Hankey Roger Hankey is offline
The image is consistent with a coated kraft paper blanket filled with cellulosic material. Did you take a scrap and flame test it outdoors?
Old 10-16-2009, 11:05 AM
Ray Babcock Ray Babcock is offline
Years ago they used to use a type of Vermiculite which when dry is fluffy and holds air a little like blown fiberglass. When mixed with soil makes a softer type soil for planting and the vermiculite holds water well so plants don't dry out so quickly.
  #6 (permalink)
Old 10-16-2009, 12:10 PM
Ray,
Can you support your statement with any references? I've studied most of the information on vermiculite for several years and not heard of what you have described. All the vermiculite info I've seen describes the material as shiny and granular.
Thanks.
  #7 (permalink)
Old 10-16-2009, 12:19 PM
I can't say for sure, the picture is not that clear. I have nothing materials to substantiate my statement other than I have seen a type of mixture of something that resembled vermiculite and something else which may have been cellulose in some very old homes here in the southwest. Most homes of the age I have found this material in were rare, because homes of this age usually had no insulation at all.
  #8 (permalink)
Old 10-16-2009, 01:20 PM
Jeffrey L. Mathis Jeffrey L. Mathis is offline
I'm betting on Vermiculite. Brown, kind of grainy. Would almost fool you into thinking old cellulose if you just glossed over it. Not to be snorted or otherwise ingested.
JLMathis
  #9 (permalink)
Old 10-16-2009, 05:19 PM
Home Energy Ed Home Energy Ed is offline
I have seen this in hundreds of 1950's constructed homes. Tar paper type material on one side, Kraft paper on the other with a sawdust/cellulosic material inside. It was installed on the underside of the roof rafters. It was not much of a breathing irritant when busted open, so I doubt there was much of a fire retardant added. I never flame tested it though.
  #10 (permalink)
Old 10-16-2009, 06:16 PM
Jerry Peck's Avatar
Quote:
Welcome aboard ... (don't know your name) ...
We use our real names here, allows us to get to know each other better. Please click on the 'Contact Us' link at the bottom of the page and ask Brian (the Administrator) to change your user name to your real name.
I will help everyone.
  #11 (permalink)
Old 10-16-2009, 07:33 PM
Steve Kassed Steve Kassed is offline
Barry,
This was very popular stuff in the "day",see it all the time in old houses in the northeast.
vermiculite/asbestos family,dist. by many companies ,IE: sears,ward,zonolite attic insul., ect,ect
key words, tremolite,zonolite,anthophylite,actinolite,crocido lite,amosite,ect.
based on where it was mined,color,application ect.
  #12 (permalink)
Old 10-17-2009, 06:34 AM
I'm reporting as unknown type and origin. There is only a 3 inch depth to it anyway and I'm suggesting that fiberglass be overlaid to increase heat/cool efficiency.
Similar Threads
Funky eletrical stuff William Slade Electrical Systems: Home Inspection and Commercial Inspection 6 07-07-2008 09:47 AM
K & B and insulation Anthony Alderman Electrical Systems: Home Inspection and Commercial Inspection 8 06-25-2008 11:32 AM
Is this insulation? Rick Burkman Attic Areas: Home Inspection and Commercial Inspection 5 06-18-2008 06:30 AM
funky sec John Arnold Electrical Systems: Home Inspection and Commercial Inspection 1 11-06-2007 01:57 PM
wet insulation dan orourke Attic Areas: Home Inspection and Commercial Inspection 4 06-24-2007 10:19 AM
vB.Sponsors
Ad Management by RedTyger
