Old 10-24-2009, 12:46 PM
Robert Autrey Robert Autrey is offline
Concealed Vertical Spaces
Yesterday I encountered a furdown above a triangular area framed in a corner of a hallway. Below, in the hallway, the area is sheathed with drywall with inset drywall shelves for art display. In the attic, however, there is a hole about 2-1/2 feet deep. Shouldn't this vertical space be firestopped at the ceiling level, or does the waferboard sheathing preclude the need for a ceiling level firestop?
Last edited by Robert Autrey : 10-24-2009 at 12:49 PM. Reason: Forgot to attach photo.
United Infrared
Old 10-24-2009, 12:52 PM
Re: Concealed Vertical Spaces
Similarly, at the same house, the draft stop (or fireblocking) at the vertical chimney chase has been penetrated at two locations. One is a CATV cable that descends from the attic through a hole that appears to have been bored by the home owner in order to mount a flat panel TV above the fireplace opening. The hole is rather large and the code indicates to me that some kind of fitting is needed to provide closure at the gap. The hole seen in the attached photo penetrates the top of the stud wall that forms the face of the fireplace (and one side of the triangular flue chase). Nearby, and directly adjacent to the fireplace flue itself, is a 4-inch flex duct that penetrates the draftstop at the ceiling level. There is also about a 1/2-inch gap at that penetration. Should these penetrations have some type of fitting as seems to be indicate in the code?
Old 10-24-2009, 08:12 PM
Jerry Peck's Avatar
Quote:
Correct, that should be fireblocked at the ceiling level.
Nope.
Old 10-24-2009, 08:14 PM
Jerry Peck's Avatar
Those need to be sealed around, yes.
Old 10-26-2009, 10:04 AM
Wayne Carlisle Wayne Carlisle is offline
In my opinion the furdown above the triangular area framed in a corner of the hallway does have the proper fireblocking.
Now the penetrations where the wires are need sealed.
  #6 (permalink)
Old 10-26-2009, 01:33 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
Also, don't ignore the energy losses in the uninsulated walls of those furdowns. A simple solution is to cover the top of the box (with something like plywood or OSB), seal the joints (to reduce air infiltration) and insulate over it.
Bruce Breedlove
www.avaloninspection.com
  #7 (permalink)
Old 10-26-2009, 05:54 PM
paul hardy paul hardy is offline
you will also note that most fireplace manufactures require the the fresh air intake opening to be lower than the top of the fire box that one appears to go up the chimney,
  #8 (permalink)
Old 10-26-2009, 07:29 PM
Quote:
While I didn't thoroughly trace the flex flue it did have a louvered type backflow damper on the exterior and I'm pretty sure it was the discharge from the master bathroom vent fan.
  #9 (permalink)
Old 10-26-2009, 07:42 PM
Jerry Peck's Avatar
Quote:
I guess it is just me, but my gut tells me that structural panel does not meet the 3/4" ( 23/32" ) minimum thickness ... I mean, how many jobs have ANY 3/4" structural panels on them?
See R602.8.1 in the IRC.
  #10 (permalink)
Old 10-27-2009, 12:43 PM
It sounds to me like it is already fireblocked and does not need any additional fireblocking.
1
/2-inch (12.7 mm) gypsum board is allowed as fireblocking.
  #11 (permalink)
Old 10-27-2009, 01:47 PM
Jerry Peck's Avatar
1
Correct.
You are allowed to use 1/2" gypsum board, but you are not allowed to use 1/2" structural panel - the structural panel would need to be 3/4" - and structural panel is what is shown, not gypsum board.
Or cover that exposed structural panel with 1/2" drywall, that would work.
Casey, O'Malley & Associates Home and Commercial Education Classes and Conferences
Similar Threads
Where does it say Vertical Installation Bob Hunt Structural Components: Home Inspection and Commercial Inspection 16 08-28-2009 01:13 PM
Vertical site built Ladder Bruce Ramsey Attic Areas: Home Inspection and Commercial Inspection 9 07-24-2008 09:23 PM
Light in storage spaces and closet mathew stouffer Electrical Systems: Home Inspection and Commercial Inspection 13 05-07-2008 05:45 PM
Vertical stucco wall Wendell Swedberg Building Envelope: Home Inspection and Commercial Inspection 10 12-23-2007 07:08 PM
Vertical Ladder dan orourke Building Interior: Home Inspection and Commercial Inspection 20 10-11-2007 10:18 PM
vB.Sponsors
Ad Management by RedTyger
