Old 06-23-2007, 08:22 AM
dan orourke dan orourke is offline
Thoughts on this
Old 06-23-2007, 08:29 AM
Phillip Stojanik's Avatar
Phillip Stojanik Phillip Stojanik is offline
Re: Thoughts on this
The work certainly is not pretty by any stretch of the imagination but I do not see a significant functional problem with this. If the alternative is to have the rafter end just floating out there then I will take the 2-by filler material instead and just mumble under my breath about it.
Old 06-23-2007, 10:53 PM
Mike Huppi Mike Huppi is offline
We do not see any of the foam on the sheathing in the Portland Oregon area. Do you have much problems with moisture under the foam?
Old 06-23-2007, 10:57 PM
The shiny material on the underside of the roof decking is not a foam product; its a radient barrier which is just a foil product glued to the plywood or OSB.
Old 06-24-2007, 12:43 AM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is offline
It's not pretty. Luckily a few feet away the rafter is supported by a post which is in turn supported by a beam.
Without knowing what is on the other side of the rafter it's hard to say what the loads are at the end of the rafter. It would have been nice if the framers had at least nailed a block between the joists below the 2X4 for additional support.
It is certainly questionable. Hard to say whether to recommend a repair without knowing more.
Bruce Breedlove
www.avaloninspection.com
Home inspection
Similar Threads
Second thoughts Michael Thomas Expert Witness and Defect Litigation: Home Inspection & Commercial Inspection 10 04-12-2007 11:09 AM
Any thoughts Dominic Egan Plumbing System: Home Inspection and Commercial Inspection 17 04-07-2007 09:21 AM
vB.Sponsors
Ad Management by RedTyger
