In many, perhaps most, cases I recommend starting with a good and knowledgeable (and, of course, licensed in Texas) home inspector, however, being as ...
Originally Posted by
Nolan Kienitz
You might try and locate a home inspector in the Midland/Odessa area, but he may ...
... he will likely do as Nolan stated, I would recommend going straight to the "structural" engineer, as Nolan stated below:
refer the observation and recommendation to a Texas Licensed Professional Engineer who focuses on "structural" engineering.
If, on the other hand, you have other concerns about the house, a knowledgeable home inspector can look at the entire house and tie the different systems together whereas individual contractors for those separate systems may (should) excel *in their trade* they typically fail to have the knowledge of all trades to be able to tie everything together.
Even if you go with the home inspector for all the advantages of doing so, I would also go with the structural engineer for your garage question - but hold off doing so until after the home inspector has done their inspection as the home inspector may also find other things the structural engineer should look at.
