In a cabin that is 20' front to back by 25'wide, I plan on using 2x8 on 12" ctr for rafters on a vaulted ceiling. Underneath will be an exposed beam. Snow load is pretty heavy as it is in upstate NY. Should I switch to 2x10 rafters on 12' ctr? Currently, there are trusses that have been damaged by previous owner(ie: cut/sistered/etc) Any input is very appreciated.
The charts I have require the following info. in order to figure.
Horz. span (not rafter length) of rafter
On center spacing used
light or medium or heavy roof covering
live load required by code in lb per SF
dead load required by code in lb per SF
drywall ceiling or not
wood species used
lumber grade used
This is what I know Bruce:
1. 20' span
2. 12 oc
3. medium-I'm putting on a metal roof over existing shingles.
4. live load-minimal,
5. dead load = 60
6. no drywall. t&g pine
7. spf
8. #2
Yep. 10' span. You should think about hiring an engineer or an architect with an engineer to design the roof for you. In my neck of the woods Regional Building Dept. would require the roof design to have a PE stamp before they would issue a building permit.
Bruce Breedlove www.avaloninspection.com
All Rights Reserved. Hann Tech Marketing Link / InspectionNews.com / InspectionNews.net - No part of InspectionNews.net may be reproduced in any way, or by any means, without the prior written permission of InspectionNews.net. Use of any index or listing Software for the purpose of constructing a mailing list, creating promotional materials or producing a printed or electronic catalog of any kind is expressly forbidden without the prior written permission of InspectionNews.net - All text, graphics and design on InspectionNews.net is copyright by Hann Tech Marketing Links. Ad Management by RedTyger
