07-06-2007, 06:43 AM
Attic access problems
I have had a few problems with getting access to the attic hatch. Yesterdays inspection the hatch was located in a small walk in closet that was chuck full of the owners cloths. I could not even get my ladder in the closet with out removing almost all of the cloths. I chose not to as the cloths were to numerous and expensive for me to move properly.
I had informed my clients that the access was not possible. My question is what should I do to solve this problem in the future or should I just report as not accessible?
I am going to in the future inform my clients to call the Realtor and inform them that the home owner must provide easy access to the attic entrance. Any input would be great,
thanks
Well thats my 2 cents.
Brian Kelly
Kelly Home Inspections
07-06-2007, 06:48 AM
Re: Attic access problems
Brian I usually ask the Realtor and client if they would remove the clothes etc so I can access the attic. I then go on to other matters and when I get back it is done. I have never had a problem as most clients know this is to there advantage.
If you can not access the attic make sure you document that it was not accessible.
Dave
07-06-2007, 07:03 AM
I was in an older house that had an attic opening of 13x15 inches. I am not a large person but I could not get my shoulders through the opening. In the cases where for some reason that I can not get into the attic at all I will alsoway not that on the report. I also inform the the buyers agent while i am still there to provide a heads up.
07-06-2007, 07:04 AM
If the attic has a scuttle hole in a closet that is full of the owners items, I simply tell everyone that they can either empty the closet, remove the hanging bars and I will be glad to inspect the attic. Most of the time nobody wants to do this so the attic is not inspected, "due to owners items blocking the access."
I really do not worry about this. I would say that out of 100 homes I might have 10 homes with an entrance like this and about 5 of those are full of crap. If I'm in a good mood and everyone is nice, I will offer to come back at my convenience when the owner cleans out the closet.
07-06-2007, 07:12 AM
Yeah, what Mr. Patterson said is the best way of handling it.
Once I attempted to place a ladder slightly against some clothing to get in the attic. As soon as I moved the panel, all of this cellulose insulation fell onto all the tops of these clothes. I tried to clean it up, but the more I tried the worse it looked on the clothes.
I was expecting the seller to raise a stinky over it, but they didn't. They apologized for not being prepared for the inspection. That you don't get very often.
07-06-2007, 08:16 AM
I try not to move occupants property. Always try to get the client, realtor, seller, etc. to move them so you are not liable. I also carry a painters drop cloth and a small vacuum cleaner to clean up the insulation.
If you cannot gain access, be sure that you document that and the reason why.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
07-06-2007, 08:26 AM
"I could not even get my ladder in the closet with out removing almost all of the cloths. I chose not to as the cloths were to numerous and expensive for me to move properly."
Hey Brian, what were those clothes made of? Waterford Crystal? TNT? Nitro glycerin?
07-06-2007, 09:02 AM
No they are not crystal or other breakable items but they are someones cloths and i did not want to destroy or damage any of them. Nick how do you deal with this situation?
Brian Kelly
07-06-2007, 09:22 AM
I tour the house upon arrival and look for attic access points. If I find a packed closet, I tell everyone that in about XX minutes I need the junk removed to gain access to the attic.
I carry a large (clean) sheet, and I will drap it over people's stuff if I need to. Have a vacuum that I just can't stand to dig out of the van, but if I need it, its there.
Dom.
07-06-2007, 10:29 AM
Just having some fun with you Brian.
Honestly, I do whatever I can to get into the attic. If there are clothes in the way, I move them aside or put them on the bed. Boxes, I move them. There are too many things to possibly find in the attic for me to let somebody's Calvin Klein collection stand in my way. It's really a judgement call each of us has to make on our own. If I saw something up on the roof that made me say "I really need to see what's going onn in that attic" then I do what I can. Sometimes the owner has permanently installed shelving in front of the closet, then it's no go.
07-08-2007, 10:51 AM
If the seller is home, I ask them to make way. If not, I will move boxes and clothes when the hatch is indeed accessible. If not I dsclaim it loudly. I find my "Telespteps" ladder is pretty good at being poked through these hatches so as not to lean on anything. The ladder's case makes a great drop cloth, and wall protector! I also carry a dirt devil and sheet. Depending on what the roof and ceilings look like, I will at times exceed standard care to get in the attic, but I know I shouldn't, it's a bit risky.
07-08-2007, 02:23 PM
I also handle it like others here. I will move some stuff if it is not too much, but if the stuff looks expensive or just too much - I don't move it.
I had a seller file a claim against me with the BBB about how I "damaged" all her clothes. She wanted something like $300 - 500.
The hatch was damaged before I went in the attic (documented in writing and photos in the report). I went in without any problems, but sometime between my inspection and her complaint (a month or so) the hatch fell and go drywall dust and some insulation on a few jackets. She had photos.
I ended up settling with BBB for something like $21.00 for cleaning 5 or six jackets.
On another house, I set my ladder against an already overloaded cloest bar and the entire thing came off the wall. I told the sellers that if they emptied the closet, I would come back and re-hang the shelf/bar. Cost me about $5.00 in materials and about half hour in time.
I too carry a sheet and a dustbuster, and put my booties (shoe covers) over the top of my ladder when it leans against the wall.
JF
07-08-2007, 07:26 PM
I'm with Jack on this one. After losing money because of damage to items I moved on a job, my standard policy is that I don't move other people's stuff.
I don't like to work for free and you never know what may be tucked in a closet behind the clothes or in a box that falls from a shelf. It is similar to why I do not light pilots, there is an unknown factor that might cost me money or worse.
My pre-inspection agreement clearly spells out that I need access to certain areas but I still make it a point to tell the client that they need to let the agents know that I need access to scuttles and panels, just like I make it clear that the utilities need to be on. The one time I don't mention these things prior to the inspection will be the one time the gas is off or I can't get to a scuttle.
If no one will move the things while I am on inspection I let them know that I can return later for an additional fee, which often times is paid by the seller or their agent since they dropped the ball. Even a rookie agent should know the drill for inspections.
07-09-2007, 10:04 AM
When I am in the midst of booking a job, I ask certain questions, one being, Is there access to the attic? And then ask if it is accessed through a closet or a drop down. Sometimes they know and sometimes they don't, but I always tell them to make sure if the access is in a closet that the closet is cleaned out, shelving is removed and the hangar rod dismantled, or I won't be able to inspect the attic. Rarely is it not done before I get there.
Fred
07-09-2007, 12:21 PM
I would try your best to get to the attic. I have personally been in at least 5 attics with some pretty good fire damage. Client may be understanding at the inspection but when they own the home it may be different story.
No disclosure on any of them. Realtors were surprised when I came down and told them.
Dave
07-09-2007, 05:04 PM
I would think you guys had some sort of info. sheet for homeowners on how to prepare the home for inspection:
what to have 'on' or 'off', accessibility, people pets and junk out of the way, utilities still 'on', somewhere to park within one space of the property lines, etc. Experience would dictate what to include. This notification could be sent to both Realtors. That way, if anything is missed, such as a problem in the attic, it makes for a better case that they knew you wanted access up there but deliberately left it inaccessible hoping you wouldn't look, therefore it is a hidden defect. Just puts everyone on notice to cooperate so you can deliver the best objective inspection of the facts as they exist on that date and time.
As for attics being inaccessible, I know some would make that a case for not getting up on the roof. We've all seen enough patch jobs that would act like a trap door if you stood on that section of roof. How about leaning against a framed chase that is simply spiked into platform framing with 3 12d nails? I've repaired a number of chases where they either blew over by wind snapping off at the roof or when someone like me leaned against them. How about when you hop down 4 feet from a chimney onto a roof decked with 1/2" plywood?
How about all the things that would not get inspected?--Chopped off chimneys, disconnected stink pipes, clearances, wiring nightmares, water damage, missing or inadequate insulation, dryer venting into insulation, non-IC rated can lights buried under insulation, rotten roof sheathing, disconnected ducts, etc. --you guys know this better than me.
If there is not accessibility into the attic, then it should be written up as such.
FYI, LittleGiant makesa combination ladder that might be of interest. Can be configured as either step or extension. I still use my Telesteps though I've been wanting a Fire Dept. attic ladder for some time. Just can't justify the cost yet. Wes, you could stop by Alco-Lite and see them being made. They invented the aluminum ladder.
Of course, there is always the ever popular chainsaw that will make the cutout for a future skylight!!! Sounds like a real PIA.
I'd like to hear from anyone who has tried this approach.
TIA,
Bob
07-09-2007, 05:34 PM
I have a sheet that I email along with my contract stating the various things that we need access to in the house. It usually helps. It does let people know ahead of time what we need to see in order to inspect properly. I don't know how often it gets all of the way to the seller, but it helps.
07-09-2007, 06:15 PM
If I can, I stick my camera up there and shoot a bunch of pictures and mention in the report that access was blocked.
07-10-2007, 07:07 AM
Yeah Bob, All of that info is included in my Pre-inspection agreement that gets faxed or emailed to the client prior to the inspection. I also verbally tell them about access to items so they can pass it on to the agent. A lot of the agents that I have dealt with are on the ball, of course I'm sure some of them roll their eyes and those are the ones I will have utilities or access proeblems with.
As far as roofs, I will get on anything that is not too steep or not too high. I have found that I can get on the majority of roofs in my area. If I can't, My ladder goes up on every side of the house so I can view from roof level and at the very least I view with binoculars. I always inform the client as soon as possible how the roof or attic is inspected and it is also written in the report.
I agree that it is very important to get in the attic (as well as the roof) and will make every good faith attempt to do so before I disclaim such items.
As always, my safety and liability comes first!!
Eric
07-10-2007, 10:03 PM
When booking the inspection I tell my clients to let let the sellers know to remove all clothes and personal items from the closet to allow me to access the attic area. Of course that information does not always get passed on so either the realtor or buyer have to remove the items, if they are blocking the access, or it just does not get inspected.
A couple weeks ago I came across an attic entrance that was painted shut and could not be removed without breaking open the entrance. My clients realtor contacted the sellers and they agreed to allow me to break the entrance.
Principles don't change with circumstances. That's what makes them principles.
-George Colombo
07-11-2007, 08:03 AM
