Share |
Welcome to InspectionNews.
Registration is FREE!
The Cost Of Business
United Infrared Inc
Old 07-29-2010, 04:51 PM
Gene South's Avatar
Gene South Gene South is offline
Thermal barrier installed wrong? See photos..What say ye?
We all have seen different types of aftermarket "Thermal" protection for attics, from silver spray paint to thermal decking, etc. This one in today's inspection utilized heavy foil paper installed and lying on top of the existing and original loose fill fiberglass insulation. All the loose fill insulation in the attic was covered by this foil. (The roof sheathing/decking was just regular wood OSB plywood). As I was looking at this today it appears to me maybe it installed wrong? ( I am thinking vapor barrier here). Assuming that you accept that a lot of mositure from inside the house makes it way to the attic and attic insulation, the mositure from the house would be trapped inside the insulation, because the attic insulation now has a foil paper covering it. From my view, this would prevent the attic loose fill insulation from "breathing". Seems this foil would hold household moisture inside the insulation rather than allowing it to escape.... What say ye insulation vapor barrier experts? I have included photos however they are not great. Look close. There is also foil covering the fiberglass wall batt insulation. I have checked a few websites and they do warn of a moisture trap in some cases.
HomeGauge Reports
Old 07-29-2010, 04:59 PM
fritzkelly fritzkelly is offline
Re: Thermal barrier installed wrong? See photos..What say ye?
I have seen this at some home shows and this is how they install it, I don't know if it's a good idea but "they" sure seem to think so.
The stuff I have seen has lots of tiny pinholes, maybe to let moisture through.
It's good that they are keeping that water heater cool.
"Only the government would believe that you could cut a foot off the top of a blanket, sew it to the bottom, and have a longer blanket" Wise Indian remarking on daylight saving time
Old 07-29-2010, 05:06 PM
Some of this stuff is pin-pricked to allow vapor to pass through. Try and feel for the bumps and shine your light through it.
You definitely do not want a vapor barrier in that position. According to studies I have read about, attic floor vapor barriers are effective but rapidly loose there radiant barrier effectiveness as the inevitable dust layer covers the product.
Allen, Texas 75002
Old 07-30-2010, 10:20 AM
Rod Butler Rod Butler is offline
The radiant barrier approach that we see in these pictures is fairly typical as long as it is not intended to be a vapor barrier. I have seen new construction with the foil barrier actually placed on the underside of the deck. The purpose is to act like a foil blanket similar to the ones used in emergency camp kits.
Vapor barrier location depends on the location. In Utah where the ambient air is dry the moisture barrier is placed on the inside of the thermal barrier. In Florida it is placed on the outside of the thermal barrier.
My 2 cents. HTH.
Old 07-30-2010, 02:56 PM
kenny martin kenny martin is offline
Looks pretty obvious there are air holes and appears sufficient to not worry about, if it was a home old enough in an area that has been through a few good heat/cold seasons you can lift an area, if it is causing any problem you will certainly see moisture evidence whether it be on the wood or elsewhere..
United Infrared
United Infrared Inc
Share |
Similar Threads
What causes this ? See photos Gene South Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 12 07-09-2010 10:51 AM
Need advice for uploading photos Bill Anglin H E L P ! 1 05-27-2010 03:48 PM
More photos of cut out Ryan Stouffer Structural Components: Home Inspection and Commercial Inspection 1 11-19-2009 04:51 PM
some inspection photos Stephen Meyer Structural Components: Home Inspection and Commercial Inspection 0 06-02-2009 09:25 PM
CELL PHONE PHOTOS FOR $120 CHARLIE VAN FLEET InspectionBlues: Home Inspectors & Commercial Inspectors 5 01-13-2009 05:50 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
vB.Sponsors
Ad Management by RedTyger
