07-22-2007, 10:07 PM
Insulation over garage
Is the garage (attached) ceiling supposed to be insulated in the attic?
Thanks,
Matt Kelekci
Houston TX
07-22-2007, 10:37 PM
Re: Insulation over garage
Yes, if it is a heated garage. If the garage is not heated then it really doesn't matter if it is insulated or not.
Bruce Breedlove
www.avaloninspection.com
07-22-2007, 10:40 PM
Thanks for the post.
No, it is not a heated/air conditioned garage.
Matt Kelekci
Houston TX
07-23-2007, 07:02 AM
So not requied. But the side wall against the living area must be , as well as fire rated.
07-23-2007, 07:16 AM
Nope. Not "fire rated".
"Separated", which simply means ... 1/2" gypsum board on the garage side.
07-23-2007, 08:06 AM
Jerry, in my area there must be a 5/8 sheetrock wall, minimal, between the living area and the garage. That is fire rated,No?
07-23-2007, 08:33 AM
We still need the fire rated door between the house and garage though, don't we?
Matt Kelekci
Houston TX
07-23-2007, 10:37 AM
No.
You would need 5/8" Type X on both sides, screws spacing as required, sealant around the edges, continuity taking priority over any other walls intersecting with it, etc., to be a fire rated 'fire wall' or 'fire partition'.
Simply installing 5/8" Type X on one side does not, to anything I've seen so far, make it a "fire rated wall".
Thus, to answer Matt's question below, no, a fire rated door is not required (of course, there may be a local code which requires a fire rated door, which would be a 20 minute rated door).
Wayne,
Does that apply to two story houses with living space above the attic, or to all dwelling units, including one story ones?
There are additional requirements I did not state above for when there is living space above the garage.
07-23-2007, 11:11 AM
As Jerry mentioned, your local code will prevail, but the IRC
requires a solid wood door min. 13/8" thick, solid or honeycomb steel doors of the same thickness, or a 20 minute fire-rated door.
Also requires 1/2" gypsum on the garage side and 5/8" type X with habitable rooms above.
Note the IRC does not require a fire separation wall as Jerry is referring to, just "separation" but the intent is clear.
This is all in IRC 2003 section R309
Mr. Inspector.net, Inc.
Allen, Texas 75002
07-23-2007, 03:27 PM
Do you mean to say if I inspect a house in City of Houston which adapted IRC, 1 3/8" thick, solid or honeycomb steel doors of the same thickness, or a 20 minute fire-rated door is required. However if house is located in another jurisdiction that has not adapted IRC and doesn't have any requirement for the garage/dwelling seperation, the same door is not a repair item to write up.
Thanks for these great posts. You guys are so helpful.
Matt Kelekci
Houston TX
07-23-2007, 03:38 PM
I write it up regardless of where I'm inspecting. It's a good idea to have a fire separation door between the garage and the house. Whether it is required or not doesn't change my opinion of why I write it. If they ask (which is almost never) I will tell them that it may not be required, but I still think it is a good idea. I've never had a problem with that explanation, which is the same for smoke alarms, GFCI's, and other safety things that change over time.
07-23-2007, 04:06 PM
Has anybody noticed any more or less ceiling drywall cracks in insulated garage ceilings vs. uninsulated in unheated garages?
What time zone is this forum on? Apparently I posted this at 11:08 pm! It's only 4:08 where I am.
Reason: NYB
07-23-2007, 04:30 PM
Code varies by jurisdiction, but stupid knows no limits.
I use the IRC as a starting place since it is the fall back code for the state on new construction warranties and is a pretty good bet on being accepted by most. Besides, I can't be an expert on all the codes and variations that are within 5 miles of my house, much less for the entire state.
As has been repeated here many times, code is the minimum. I will often recommend something that is not "code", but it is a good starting place.
As far as your specific question about a door, there may well be a more stringent requirement or no requirement at all, but I will write up a hollow core door or one with a window every time, code or not.
Allen, Texas 75002
07-23-2007, 05:13 PM
I believe you can set the time zone in your preferences.
07-23-2007, 06:46 PM
No, humidity is one real killer on dry wall joints and is where I usually see cracks.
Lots of builders don't paint garage interiors and that seems to have much more impact than insulation.
Allen, Texas 75002
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| wet insulation |
dan orourke |
Attic Areas: Home Inspection and Commercial Inspection |
4 |
06-24-2007 09:19 AM |
| Great Foam Insulation |
John Stephenson |
6 |
05-18-2007 11:53 AM |
| Insulation |
John Stephenson |
5 |
05-17-2007 04:14 PM |
| Electrical cable insulation cover |
John Stephenson |
4 |
05-16-2007 08:25 PM |
| Insulation type |
Jeff Eastman |
6 |
04-07-2007 08:47 AM |
