08-19-2007, 10:20 AM
roof decking gap
10-02-2007, 07:35 PM
Re: roof decking gap
Sloppy work but not really worth making a note of. I'm sure someone will disagree
10-03-2007, 04:07 AM
The gap, in all likelihood is inconsequential.
There are multiple layers of roofing in the valley and they'll easily span that hole. It'd be nice to see some metal flashing through the hole though.
10-03-2007, 05:48 AM
No real code violation there. Like Bill said...just sloppy work. Before plywood, builders used planking for roof decking often of varying widths and this created lots of gaps, sometimes large. As long as the roofer did his job correctly there should be no problems. Agreed...it would be nice to see some metal flashing showing through, but I personally would not include this one in the report as a problem.
10-03-2007, 12:49 PM
"It'd be nice to see some metal flashing through the hole though."
If you could see metal (flashing), that would mean, there is not any roofing felt in that valley.
Rick Cantrell
10-03-2007, 02:42 PM
Rick...true datt!
10-03-2007, 03:21 PM
If I see something like that I will often mention it, even if I don't think it needs to be corrected. It lets people know that I was looking and in the attic. It can also head off questions later on when they do look in the attic for themselves.
What is the circumference of a moose?
10-03-2007, 03:29 PM
It could be a problem if the next Home Inspector happens to be wearing high heels.
You just never know nowadays.
I came across a female inspector the other day and I sh*# you not, she had a granny kitchen apron on with some of her tools in the pockets. WTFudge?
It wouldn't have been so bad, but the bunnies and chickens on the apron was a bit much.
10-03-2007, 04:59 PM
Jim R,
Said His crawl Kit is in a Chip & Dale Rescue Rangers Lunch Box.
I'm still looking Jim I might have to settle for a Quick Draw McGraw or Mighty Mouse.
Billy J. Stephens HI Service
10-03-2007, 05:11 PM
Something I just noticed is that the OSB is not run perpendicular to the joist.
Rick Cantrell
10-03-2007, 10:52 PM
Rick...ya never can tell. In 21 years I had never seen a female inspector until my recent continuing education class. In class we had a female architec turned HI who said she wouldnt go into certain crawlspaces because they might be full of wookalares... soooo, whats a wookalare????
10-03-2007, 11:27 PM
Wookalars are demonic Creatures of the Dark.
They will take out a HI in no time. Be on the look out for them.
10-04-2007, 03:23 PM
Oh, I get it ....so basically your saying it's another word for "mother-inlaw"
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Roof Framing |
Jim McClendon |
Attic Areas: Home Inspection and Commercial Inspection |
8 |
07-21-2007 03:02 PM |
| Roof sag? |
Scott Lynch |
Roofing System: Home Inspection and Commercial Inspection |
2 |
07-20-2007 02:10 PM |
| Vapor barrier tacked to crawl decking |
Matt Fellman |
Sub-Structure: Home Inspection and Commercial Inspection |
9 |
07-15-2007 08:01 PM |
| Tile Roof Help Please |
Matt Hawley |
3 |
07-04-2007 05:25 AM |
| Roof decking |
Jeff Eastman |
3 |
04-15-2007 08:01 AM |
