Old 08-24-2007, 11:17 AM
Ron Bishop Ron Bishop is offline
foil backed roof sheathing
Does anybody know what the foil backed roof sheathing is known as??
Old 08-24-2007, 11:57 AM
Re: foil backed roof sheathing
roof sheathing with radiant barrier attached
radiant barrier roof sheathing
The foil is a radiant barrier which is peel and stick attached to the bottom of the roof sheathing.
Old 08-24-2007, 11:58 AM
Jim Dull Jim Dull is offline
I believe it is called radiant barrier sheathing. There is an article about it at Fine Homebuilding - trusted residential construction, home design, and renovation articles, videos, magazines, and books
Old 08-24-2007, 01:56 PM
thank you kindly
Old 09-05-2007, 07:27 PM
Bill Wieczorek Bill Wieczorek is offline
I recently saw a home where the sheeting was painted a silver color. This was on the back side of the sheeting. I was told they do that to reflect heat. Are they pulling my chain or is that something fairly new ?
  #6 (permalink)
Old 09-05-2007, 08:04 PM
Quote:
Did any bells ring when they pulled the chain?
Actually, ... well, ... it 'seems to me' that silver paint would only reflect the heat in the attic back into the attic, and not have much effect on the heat coming through, then again, maybe it is like silvering on the back of glass ... it makes it a mirror, reflecting back out the way it came in.
I'd ask for some "documentation" on the paint, the process, its effectiveness, its application, and its acceptability for use as an approved product (i.e., *show me the product approval* ).
They should be able to provide *something* which backs them up, or I would not have any faith in it.
  #7 (permalink)
Old 09-06-2007, 08:34 AM
The guy building this monster is the general contractor and appears to be in over is head. He's overspent his budget for the framing and roofing and now it seems to have a problem paying the contractor doing the stucco. He's a painter by trade who thought he could handle this, he's finding out there's more to it then he can handle. Seems like he was sold a bill of goods when they painted the inside of the sheeting with silver paint.
I saw the home when an inspector friend was doing a draw inspection. By the way Jerry there were no bells when my chain was pulled, thanks for asking.
  #8 (permalink)
Old 09-06-2007, 09:44 AM
Check out this link.
http://www.sherwin-williams.com/pro/..._FactSheet.pdf
Radiant barriers of the foil film type typically claim about 97% effective at blocking radiant energy, while paints are down in the 60-70% range.
On a new home I would spring for the radiant barrier decking, not too sure about the paint.
http://edis.ifas.ufl.edu/pdffiles/EH/EH24500.pdf Here is a article that Jerry P. helped pay for.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #9 (permalink)
Old 09-06-2007, 11:27 AM
Eric Shuman Eric Shuman is offline
I know this doesn't have much to do with the original topic but out of the 4 attics I have been in since Saturday (during afternoon inspections), 2 had the radiant barrier (foil type) in them and I could definitely tell a difference in the attic temperatures between those with the barrier and those without. All houses were similar in age and construction and the ones with the barrier were noticeably cooler judging by my sweat meter (shirt saturation ). I have yet to see the silver paint type unless you count the houses that had previous fires.
Eric
  #10 (permalink)
Old 09-06-2007, 02:11 PM
Bill,
That's the bell I was referring to.
  #11 (permalink)
Old 09-07-2007, 02:53 PM
Marcel Gratton Marcel Gratton is offline
Quote:
Eric
That's what came to mind...
  #12 (permalink)
Old 09-07-2007, 03:48 PM
imported_John Smith imported_John Smith is offline
The paints are beginning to gain popularity around Houston.
Check out the Oak Ridge National Laboratory web site for studies on performance of radiant barriers.
Energy efficient roof coating from Sherwin-Williams
' + title + ' - ' + basename(imgurl) + '(' + w + 'x' + h +')
  #13 (permalink)
Old 09-13-2007, 12:59 PM
John Carroll John Carroll is offline
FYI-Some of the more progressive thinking builders in this area are starting to use radiant barrier as a underlayment for one coat stucco systems. It has the advantage of allowing the stucco subs to use the regular foam at the attic spaces instead of AIS board or R-Guard.
I'm sure the reduced heat is minimal tho, because they have yet to require the foil on the roof sheathing....oh, well, they are after all dinosaurs. I guess we should be thankful for the small steps...
Home inspection
Similar Threads
Flue against roof sheathing Ken Milton Introductions By New Members 6 07-29-2007 09:11 PM
3/8" plywood roof sheathing Kenton Shepard Attic Areas: Home Inspection and Commercial Inspection 10 07-26-2007 01:08 PM
Roof Sheathing Repair? Larry Vance Roofing System: Home Inspection and Commercial Inspection 1 07-19-2007 08:38 AM
Wood Structural Panel Sheathing or Siding Used to Resist Combined Shear & Uplift Brian Hannigan Building Envelope: Home Inspection and Commercial Inspection 0 05-23-2007 12:16 PM
Foil tape on vent pipe Jeff Eastman Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 5 05-18-2007 04:12 PM
vB.Sponsors
Ad Management by RedTyger
