Old 01-30-2008, 02:47 PM
Frank Bombardiere Frank Bombardiere is offline
SPF insulation
I don't see this stuff much at all and have a question. Does this spray foam insulation blown onto the underside of the roof framing require a fire retardant coating be sprayed over it?
And no, that is not a flue, it is a fresh air intake for the ventilation system.
Old 01-30-2008, 03:54 PM
Re: SPF insulation
Quote:
.No..
Old 01-30-2008, 04:46 PM
John Arnold John Arnold is offline
Re: SPF insulation
Quote:
.No..
Ok, waiting for the other shoe to drop.
When all JP has to say is "No", you have to wonder.
Hey, I just realized what the three dots are for - minimum 5 characters!
Anyway, this has been discussed fairly recently - if you search the forum for "attic foam insulation" without the quotes, I think you'll find some useful info.
Old 01-30-2008, 06:23 PM
Re: SPF insulation
Quote:
.Yep.
I figured that this was old by now:
Charlie Chaplain
Buster Keaton
Lucille Ball
Stan Laurel
Oliver Hardy
Old 05-25-2008, 07:12 AM
Darrel Hood Darrel Hood is offline
Re: SPF insulation
I know this an old thread and I am a new guy to this forum. However, the correct answer is "probably no". Based on fire safety testing a few brands require the barrier.
  #6 (permalink)
Old 05-25-2008, 05:09 PM
Re: SPF insulation
Quote:
Darrel,
Would you give us those brands and the code section which applies to that requirement?
Thanks.
Similar Threads
Attic insulation Rick Cantrell Attic Areas: Home Inspection and Commercial Inspection 11 01-19-2008 06:34 AM
Insulation over garage M Kelekci Attic Areas: Home Inspection and Commercial Inspection 14 07-23-2007 06:46 PM
wet insulation dan orourke Attic Areas: Home Inspection and Commercial Inspection 4 06-24-2007 09:19 AM
Insulation John Stephenson Attic Areas: Home Inspection and Commercial Inspection 5 05-17-2007 04:14 PM
Insulation type Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 6 04-07-2007 08:47 AM
vB.Sponsors
Ad Management by RedTyger
