Old 03-02-2008, 09:27 AM
Jim Dull
Posts: n/a
Lots of Insulation
How do you inspect an attic when it is this full of insulation?
Old 03-02-2008, 09:32 AM
Jim Dull
Posts: n/a
Re: Lots of Insulation
Sorry. Forgot the pic
Old 03-02-2008, 09:42 AM
Nick Ostrowski Nick Ostrowski is offline
All you can do Jim is look at what you can see and get to and disclaim the rest. I know some guys will not walk in an attic that has the floor covered with insulation and has no floor decking but if you take your time and feel for the joists with your feet, you can make your way around in the attic. You just can't see everything.
Old 03-02-2008, 10:06 AM
Jim Dull
Posts: n/a
Thanks Nick. Yeah, I agree. I will always feel my way around if possible but this one wasn't.
Old 03-02-2008, 11:52 AM
Patrick Norton Patrick Norton is offline
Jim, I will climb in the trusses or framing as much as I can but I don't disturb the insulation levels where not already disturbed.
www.nortoninspection.com
  #6 (permalink)
Old 03-02-2008, 11:57 AM
I won't step on a truss or joist where I can't 'wiggle' the insulation away with my foot and see or feel wood. Too many mechanicals to step on, damage and/or be hurt by. A lot depends on the pitch of the roof. If I can basically stand up I'll make a run down the middle. Something like that picture? No way... I look from about the point where you took the picture.
  #7 (permalink)
Old 03-02-2008, 01:14 PM
Gunnar Alquist's Avatar
Quote:
"Attic was viewed from the access hatch. Attic was not entered due to restricted clearance, insulation covering joists and the possibility of damaging finished ceilings. Client is advised that inspection of this area was limited."
Either that or you swim through. Personally, I like getting insulation in all of my orifices.
The apostrophe troll.
  #8 (permalink)
Old 03-02-2008, 02:46 PM
That being said, I still make an effort whenever possible to get to the areas around the heating flue pipes and other roof penetrations to look for evidence of leaks. If there is a type B flue vent running through the attic, chances are pretty good that there will be something in contact with the pipe that shouldn't be like piled up insulation. It's also good to push back the insulation around the flue pipe and make sure the penetration is firestopped.
  #9 (permalink)
Old 03-02-2008, 03:08 PM
Rick Hurst's Avatar
Thats not really a problem.
You just take one of those gas powered lawn blowers and start working towards the rear of the attic.
When you make it to the end of the attic, you reverse the process but try to keep the insulation from blowing back through the attic opening.
  #10 (permalink)
Old 03-02-2008, 05:11 PM
Nolan Kienitz's Avatar
Nolan Kienitz Nolan Kienitz is offline
"Float like a butterfly"
Cheers - Nolan E. Kienitz, HCRI, PMP
ICC Certified Residential Plumbing Inspector (P-1)
www.NolansInspections.com
  #11 (permalink)
Old 03-03-2008, 01:18 PM
Craig Olsson Craig Olsson is offline
I will not enter an attic space in which the tops of the joists are covered with insulation. Even though I can probably wiggle my foot around and find solid footing, the insulation is compressed or otherwise disturbed by walking on it, thereby reducing its insulation properties and damaging the insulation "system". My inspections do no damage. I report and disclaim.
  #12 (permalink)
Old 03-03-2008, 02:36 PM
Greg Subick Greg Subick is offline
I felt around with my foot once too.....and ended up with one leg in the bedroom below me.
Price of inspection: $275
Price for repairs: $480
Lesson: "limited evaluation"
Home inspection
Similar Threads
SPF insulation Frank Bombardiere Attic Areas: Home Inspection and Commercial Inspection 5 05-25-2008 06:09 PM
reversed insulation? Jerome W. Young Attic Areas: Home Inspection and Commercial Inspection 2 01-16-2008 05:52 PM
lots o' copper John Arnold Roofing System: Home Inspection and Commercial Inspection 2 08-23-2007 08:21 PM
wet insulation dan orourke Attic Areas: Home Inspection and Commercial Inspection 4 06-24-2007 10:19 AM
Insulation John Stephenson Attic Areas: Home Inspection and Commercial Inspection 5 05-17-2007 05:14 PM
vB.Sponsors
Ad Management by RedTyger
