Old 04-01-2008, 08:46 AM
Rick Hurst's Avatar
Turbine Clearance from Flue(s)?
What is the recommended clearance for turbines and Flue(s)? (3) feet?
Got the wood decking clearance observation also.
Old 04-01-2008, 09:10 AM
Re: Turbine Clearance from Flue(s)?
Rick,
First, a question:
WTF is that other termination?
I see the wind turbine, and the (what looks like) gas vent, but the other hooded four side top thingy (technical term) ...
Also having difficulty following your inside the attic photo.
- The exterior orientation of the wind turbine and the other 'thingy' is such that the 'thingy' is higher up the roof than the turbine, however, based on the photo ... is the photo showing the end of the OSB left hanging and unsupported, or is that a real nice and clean saw cut?
- Assuming that the further away 2x is the rafter, and the closer (lower) 2x is a purlin, then it makes sense and the 'thingy' is higher up the roof, but ...
- The 'thingy' is supplied with what looks like Type B Gas Vent - and the exterior photo does not show a Type B Gas Vent Cap on it.
Regarding your question, though, not sure if there is any minimum clearance between the two.
The 3 feet (above) only applies to "forced air inlets":
- G2427.6.7 (503.6.7) Forced air inlets.
Gas vents shall terminate not less than 3 feet (914 mm) above any forced air inlet located within 10 feet (3048 mm).
Old 04-01-2008, 09:27 AM
Rick Hurst's Avatar
That 4 sided thingy is connected to the WH flue which was Transite pipe also. Hello asbestos.
Your correct in the observation of the roof decking. Someone went wild with the sawsall cutting out the opening for the turbine.
Rick Hurst
Home Works Inspection Co.
5 out of 4 people have trouble with fractions
Old 04-01-2008, 09:32 AM
Rick Hurst's Avatar
I had heard that the venting from turbines could draw flue gases from combustion appliances such as water heaters.
Rick Hurst
Quote:
Sooo ... you've got more to write up than 'just the unlisted gas cap'?
Home inspection
Similar Threads
Clearance question Frank Bombardiere Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 2 03-21-2008 07:43 PM
Service Clearance allen elliott Electrical Systems: Home Inspection and Commercial Inspection 3 03-20-2008 03:26 PM
turbine vents RobertSmith Roofing System: Home Inspection and Commercial Inspection 20 12-18-2007 01:46 PM
Clearance for an air conditioner Kevin Luce Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 7 08-20-2007 10:41 AM
Gas Fireplace Chimney Clearance Jon mackay Fireplaces, Chimneys and Solid Fuel Burning Appliances: Home Inspection and Commercial Inspection 15 05-16-2007 03:18 PM
vB.Sponsors
Ad Management by RedTyger
