You are currently viewing InspectionNews as a guest which gives you limited access to view most discussions but not pictures. There are over 4,500 inspectors who have already joined. By joining InspectionNews you will be able to see the pictures, have access to post topics, communicate privately with other members, respond to polls, upload content and access many other special features. Registration is fast and simple so please, join InspectionNews today!
Old 05-02-2008, 12:32 PM
Rick Hurst's Avatar
Rick Hurst Rick Hurst is online now
Type of Insulation?
What type of insulation is this? Having a senior moment here.
Anyone, anyone, Bueller?
Also check your pictures well. Embarrassed to say, I had not noticed that the flue pipe was separated till I got back to the office and scanned my pictures. I was more into the opening around the flue and the type of insulation at that moment. My bad.
Old 05-02-2008, 12:52 PM
David Banks David Banks is offline
Re: Type of Insulation?
Rick. I am not sure from pic but maybe Loose fill Balsom or Rock wool. Most of the Cellulose I see is white.
Dave
Old 05-02-2008, 01:04 PM
Are you sure that flue is split? It looks like it's at a twisting elbow which could explain the offset look.... just a thought.
Old 05-02-2008, 01:28 PM
I'm thinking cellulose - most of what I see is either that color or a dark gray color.
You didn't mention, but I'm sure you got, the insulation around the vent/flue. Looks like a nice insulation baffle around that vent/flue ... sure did keep the insulation in around it pretty darn good.
I don't see it separated either, looks like a fire stop support with a support ring around the vent/flue.
What the opening does do, though, is allow you to see that there are no supports holding that vent/flue (other than the fire stop with support collar). As I under it, each section needs to be supported???
Construction Consultant
Old 05-02-2008, 03:01 PM
Jim Zborowski Jim Zborowski is offline
From the brown coler and texture, I'm thinking maybe Zonalite.
  #6 (permalink)
Old 05-02-2008, 10:38 PM
Cellulose
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #7 (permalink)
Old 05-03-2008, 12:19 AM
Michael Thomas's Avatar
Hard to tell at that resolution, but it looks most like cellulose, does NOT look like the Zonolite I see in my area. My first take was also that that’s an offset rather than a disconnected flue - again, hard to tell at this resolution. Also, is that lower portion single-wall pipe? In either case, is there sufficient clearance where it appears to penetrate the ceiling below?
BTW, this is why 1) I don’t do on-site reports and 2) I shoot lots of pics at full resolution (I realize the resolution in Rick’s photo is likely reduced for posting here).
  #8 (permalink)
Old 05-03-2008, 08:07 AM
Richard Rushing's Avatar
No doubt in my mind that this is cellulose.
rich
Richard Rushing, HCRI
Duncanville, Tx.
  #9 (permalink)
Old 05-04-2008, 12:23 PM
David J. Smith David J. Smith is offline
How about peat moss? Seen it in a few older homes here, have a picture somewhere, complete with the paper bags it came in.
  #10 (permalink)
Old 05-06-2008, 05:34 AM
BARRY ADAIR's Avatar
BARRY ADAIR BARRY ADAIR is offline
Quote:
David, thanks for the pic. I've looked for one to verify material for one of those "arguable deals" in the past.
It's not common around here but I've found this in at least 4 homes that I can recall.
It was fairly compacted and combustible, when "tested outside of the attic."
Don't assume that the chopped material is cellulose.
Most old and new cellulose that I run across is greyish not brown, but there may be some brown around.
I advised removal and replacement with new material.
Residential-Commercial-Construction-EIFS-Infrared Thermography
  #11 (permalink)
Old 05-07-2008, 05:02 PM
Mike Schulz's Avatar
Mike Schulz Mike Schulz is offline
cellulose
In older homes around here the stuff that is exposed turns brown but if you dig down a bit it should be grayish color. Some times you can see the print on some of the particles. Be a great puzzle.
Mike Schulz License 393
Affordable Home Inspections
www.houseinspections.com
Similar Threads
what type of disconnect is this Jerome W. Young Electrical Systems: Home Inspection and Commercial Inspection 5 03-23-2008 07:39 PM
type 1 enclosure Jerome W. Young Electrical Systems: Home Inspection and Commercial Inspection 12 01-28-2008 07:00 PM
Type of gas pipe Greg Jenkins Plumbing System: Home Inspection and Commercial Inspection 5 05-23-2007 05:57 PM
Roof Type David Banks Roofing System: Home Inspection and Commercial Inspection 5 05-01-2007 04:49 AM
Insulation type Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 6 04-07-2007 08:47 AM
vB.Sponsors
Ad Management by RedTyger
