06-10-2008, 06:48 PM
crazy looking truss
I have never seen trusses like these before. The house was built in 1979. The roof structure appeared fine. What could be the reason for the gap where the gussets are located? Anyone no what the hole in the gussets is for?
Greg Jenkins
06-10-2008, 06:52 PM
Re: crazy looking truss
Look like a good place to run some Electrical wire!!!
06-10-2008, 07:19 PM
It looks like a hinged truss to me. The truss is designed to be folded up for ease in transport (usually for long span trusses; also seen often in modular homes)
06-10-2008, 08:52 PM
Greg,
Were those factory pressed in gusset plates with the hole 1 piece ? If so would think they were for utility line access.
If they are 2 piece my concern would be it's missing a structural connector rod that would fit through the hole from truss to truss.
Billy J. Stephens HI Service
06-11-2008, 03:38 AM
What Steve said.
06-11-2008, 11:54 AM
Nothing about these trusses gave the appearance that they hinged. The gusset is one piece with a hole through the middle. They looked like they were installed in a factory.
However, the gusset on the top part of the truss at the ridge (not visible in the picture) was made of wood and appeared to be nailed together on site.
Greg Jenkins
06-11-2008, 01:05 PM
Look REAL CLOSE, Greg.
The holes are the swivel between the two truss plates.
I don't usually see this except on a manufactured home or a modular home.
Was the home identified as manufactured or modular.
Here's just one example for you.
Scherer Brother Lumber Company - MiTek Truss Products
06-11-2008, 01:42 PM
Ding, Ding, Ding... and we have a winner.
Mr. Inspector.net, Inc.
Allen, Texas 75002
06-11-2008, 07:29 PM
But they look like they are not installed correctly.
06-11-2008, 07:33 PM
Billy,
The setup you showed is for a different purpose.
The ones in the photo are designed to allow the upper part of the truss to be swung down during transport, making the overall height of the transported modular unit low enough to clear bridges and overpasses.
When set up on site, the upper portion is swung back up into place and then mated with the other matching like truss from the other modular unit being mated to the first one.
06-11-2008, 07:40 PM
Originally Posted by Jerry Peck
Billy,
Lot's to learn,
Thanks.
| Thread Tools |
Search this Thread |
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
| Crazy Electrician. |
Zibby Swieca |
15 |
03-01-2008 09:53 PM |
| Crazy Electrician |
Fritz Kelly |
5 |
01-17-2008 05:15 PM |
| repaired truss |
Robert A. Kuzmick |
Attic Areas: Home Inspection and Commercial Inspection |
0 |
10-08-2007 07:43 AM |
| What kind of Truss is this |
Bill Wieczorek |
6 |
09-25-2007 02:41 PM |
| cut truss |
Robert A. Kuzmick |
8 |
07-26-2007 02:15 PM |
