Old 06-10-2008, 07:48 PM
Greg Jenkins Greg Jenkins is offline
crazy looking truss
I have never seen trusses like these before. The house was built in 1979. The roof structure appeared fine. What could be the reason for the gap where the gussets are located? Anyone no what the hole in the gussets is for?
Greg Jenkins
Old 06-10-2008, 07:52 PM
Ron Bibler Ron Bibler is offline
Re: crazy looking truss
Look like a good place to run some Electrical wire!!!
Old 06-10-2008, 08:19 PM
Steve Frederickson Steve Frederickson is offline
It looks like a hinged truss to me. The truss is designed to be folded up for ease in transport (usually for long span trusses; also seen often in modular homes)
Old 06-10-2008, 09:52 PM
Billy Stephens's Avatar
Billy Stephens Billy Stephens is offline
Quote:
Greg,
Were those factory pressed in gusset plates with the hole 1 piece ? If so would think they were for utility line access.
If they are 2 piece my concern would be it's missing a structural connector rod that would fit through the hole from truss to truss.
Billy J. Stephens HI Service
Old 06-11-2008, 04:38 AM
John Arnold John Arnold is offline
Quote:
What Steve said.
  #6 (permalink)
Old 06-11-2008, 12:54 PM
Nothing about these trusses gave the appearance that they hinged. The gusset is one piece with a hole through the middle. They looked like they were installed in a factory.
However, the gusset on the top part of the truss at the ridge (not visible in the picture) was made of wood and appeared to be nailed together on site.
Greg Jenkins
  #7 (permalink)
Old 06-11-2008, 02:05 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Look REAL CLOSE, Greg.
The holes are the swivel between the two truss plates.
I don't usually see this except on a manufactured home or a modular home.
Was the home identified as manufactured or modular.
Here's just one example for you.
Scherer Brother Lumber Company - MiTek Truss Products
Erby Crofutt, Georgetown, KY
B4U Close Home Inspections & Radon Testing
www.b4uclose.com www.kentuckyradon.com
  #8 (permalink)
Old 06-11-2008, 02:42 PM
Ding, Ding, Ding... and we have a winner.
Mr. Inspector.net, Inc.
Allen, Texas 75002
  #9 (permalink)
Old 06-11-2008, 08:29 PM
Quote:
But they look like they are not installed correctly.
  #10 (permalink)
Old 06-11-2008, 08:33 PM
Billy,
The setup you showed is for a different purpose.
The ones in the photo are designed to allow the upper part of the truss to be swung down during transport, making the overall height of the transported modular unit low enough to clear bridges and overpasses.
When set up on site, the upper portion is swung back up into place and then mated with the other matching like truss from the other modular unit being mated to the first one.
  #11 (permalink)
Old 06-11-2008, 08:40 PM
Quote:
Billy,
Lot's to learn,
Thanks.
Similar Threads
Crazy Electrician. Zibby Swieca Electrical Systems: Home Inspection and Commercial Inspection 15 03-01-2008 10:53 PM
Crazy Electrician fritzkelly Electrical Systems: Home Inspection and Commercial Inspection 5 01-17-2008 06:15 PM
repaired truss Robert A. Kuzmick Attic Areas: Home Inspection and Commercial Inspection 0 10-08-2007 08:43 AM
What kind of Truss is this Bill Wieczorek Attic Areas: Home Inspection and Commercial Inspection 6 09-25-2007 03:41 PM
cut truss Robert A. Kuzmick Attic Areas: Home Inspection and Commercial Inspection 8 07-26-2007 03:15 PM
vB.Sponsors
Ad Management by RedTyger
