Old 06-17-2008, 11:28 AM
Rick Burkman Rick Burkman is offline
Is this insulation?
I inspected a house yesterday that had a type of insulation that I have not seen before. It looked like cotton batting in long, tubes of thin perforated red plastic. The material was all white, relatively fine, not coarse like normal fiberglass insulation, and the tubes were laid between the joists. The photo shows some of the insulation that was stuffed in place above the attic access stairs. Any idea what this is? Thanks!
Old 06-17-2008, 11:38 AM
Dom D'Agostino Dom D'Agostino is offline
Re: Is this insulation?
It looks like bagged fiberglass insulation. Made by several companies, it is sized to fit into wall cavities or joist spaces for the DIY crowd. The plastic keeps the "itch factor" down while installing the stuff.
Dom.
Old 06-17-2008, 09:48 PM
Randy Clayton Randy Clayton is offline
It is a type of fiberglass I rann across this a few weeks ago.
Old 06-17-2008, 10:22 PM
Scott Patterson's Avatar
Quote:
Yep it is made by Owens Corning. Sold at the Big Box stores. It really works well. It comes in a box and once you open it and take off the outside wrap it just about triples in size. The red plastic acts like a vapor barrier but it does not matter what side you place it on. I have used it on a few projects. I think it has an R19 rating.
Scott Patterson
Old 06-18-2008, 06:09 AM
Thanks everyone - I learn something new everyday out there (and here!).
Rick
  #6 (permalink)
Old 06-18-2008, 06:30 AM
I wonder how that red plastic does when laid over and around recessed lights ...
Similar Threads
SPF insulation Frank Bombardiere Attic Areas: Home Inspection and Commercial Inspection 5 05-25-2008 06:09 PM
Lots of Insulation Jim Dull Attic Areas: Home Inspection and Commercial Inspection 11 03-03-2008 02:36 PM
wet insulation dan orourke Attic Areas: Home Inspection and Commercial Inspection 4 06-24-2007 10:19 AM
Insulation John Stephenson Attic Areas: Home Inspection and Commercial Inspection 5 05-17-2007 05:14 PM
Insulation type Jeff Eastman Attic Areas: Home Inspection and Commercial Inspection 6 04-07-2007 09:47 AM
vB.Sponsors
Ad Management by RedTyger
