Old 06-25-2008, 09:09 PM
Peter Wigle's Avatar
Peter Wigle Peter Wigle is online now
Name for this OLD loose insulation?
Found this in the attic of a 140 year old house. Combination of wood shavings, vermiculite (if it can be white), and some hard bits of stuff which looks like plaster mud or stone/mineral. Is there a name for this mixture, or is it just some random by-product?
Thanks,
Home inspection
Old 06-25-2008, 10:30 PM
Gunnar Alquist's Avatar
Re: Name for this OLD loose insulation?
Peter,
You run into some weird stuff! I would say it is a composite of vermiculite and wood shavings and be done with it. Probably not enough insulation anyway.
The apostrophe troll.
Old 06-26-2008, 04:45 AM
Jon Randolph Jon Randolph is offline
Possibly asbestos containing material.
Integrity Inspection Service, LLC
www.irsindy.com
(317) 345-1828
Old 06-26-2008, 08:03 AM
Peter,
I would simply describe it as you did, then add Gunnar's and Jon's comments:
Attic Insulation:
Quote:
Originally Posted by Peter Wigle View Post
Combination of wood shavings, vermiculite (if it can be white), and some hard bits of stuff which looks like plaster mud or stone/mineral. Is there a name for this mixture, or is it just some random by-product,
Quote:
Quote:
Pretty much describes it, advises it is likely not of much use, and warns as to what *it might* contain.
The only other thing I would add is "Potentially a fire hazard." When talking with your client, if you tested it to see if it ignites, you could say 'Makes good kindling for starting fires. I tested some outside, want to see it go up in flames?'
Did you try to ignite some (not in the attic, of course, but outside)?
Old 06-26-2008, 08:04 AM
Agree with Gunnar, looks like vermiculite with other stuff. Tell the client to have it tested. They can put some in a baggie and send it off to a lab. Costs about 50-75 bucks around here.
Markus Keller
  #6 (permalink)
Old 06-26-2008, 08:07 PM
Quote:
Keep in mind that a negative test for asbestos does not mean that asbestos is not present in the vermiculite, only that it wasn't found in the sample submitted and analyzed.
www.irsindy.com
(317) 345-1828
Similar Threads
K & B and insulation Anthony Alderman Electrical Systems: Home Inspection and Commercial Inspection 8 06-25-2008 11:32 AM
SPF insulation Frank Bombardiere Attic Areas: Home Inspection and Commercial Inspection 5 05-25-2008 06:09 PM
Loose neutral. David Banks Electrical Systems: Home Inspection and Commercial Inspection 19 04-15-2008 06:30 AM
wet insulation dan orourke Attic Areas: Home Inspection and Commercial Inspection 4 06-24-2007 10:19 AM
Insulation John Stephenson Attic Areas: Home Inspection and Commercial Inspection 5 05-17-2007 05:14 PM
vB.Sponsors
Ad Management by RedTyger
