    Michael Vasquez's Avatar
    Michael Vasquez Guest
    Default expansion joint in brick siding
    I have seen some expansion joints sealed with sealant and some filled with mortar. Which is the correct way to fill the joints.
    Default Re: expansion joint in brick siding
    Foam rodding and caulking.
    What would be the sense of taking a joint that is suppose to allow for movement and seal it up with solid concrete.
    Quote Originally Posted by Michael Vasquez View Post
    As Ted said, foam backer rod and flexible sealant like silicone. I have also seen the joint filled with butyl rubber compound.
    Mortar will crack out and could actual cause the wall to crack in another location if movement occurs in the structure.
    The key to any expansion joint is to have two sided adhesion and not three sides stuck together. So the backer rod prevents the sealant from sticking to the substrate/sheathing and only to the brick on each side of the joint.
    Thanks, I appreciate the response.
    Sep 2008
    Texas
    Here's a pdf document on an expansion joint.
    http://www.wbdg.org/pdfs/edg/wall_20...ne_vexpjnt.pdf
