Results 1 to 37 of 37
Thread: Deforming vinyl siding
11-13-2008, 06:47 PM #1
I did a consult for a homeowner today. His vinyl siding on the northeast side was all deformed. Normally, this is due to the installer not allowing for movement in the siding (nailing too tight). I popped a piece off and the nailing - at least at this spot - was properly done (the siding was floating). So what the heck is causing this? There is a 3/4 inch thick layer of foam board under the siding with an older clapboard siding under that. The roof is newer. There was no evidence of water penetration through the siding and underlayment, nor was there evidence of excessive moisture levels in the home. No other siding sections showed this. No heat related issues on this side either (it doesn't get much sun). I'm stumped...
Any thoughts on this.
11-13-2008, 07:20 PM #2
Re: Deforming vinyl siding
The way the damage proceeds down along a diagonal and the fact that there is damage to the shutter makes me wonder if something on the ground could have been reflecting concentrated sunlight onto the wall,
11-13-2008, 07:36 PM #3
Looks like a weiner roast that got out of control -2 logs to many causing the vinyl to relocate.
11-13-2008, 08:03 PM #4
I have to go with heat also. Maybe a window reflecting the sun on that side???
11-13-2008, 08:14 PM #5
11-14-2008, 03:54 AM #6
Ernie - there's damage to the windows there too. Ask the owner if he sprayed something on that siding to clean it. Siding cleansers use a lye - maybe he put something on there acidic? Garden chemicals? Bug sprays? Any of that which reacted to the sun? The fact that it is so localized seems to indicate that something got on it or reflected to it, as suggested above.
11-14-2008, 04:52 AM #7
Only two possibilities I can see 1) high heat reflected or flash flame
2) solvent based product applied to diding
11-14-2008, 06:57 AM #8
That really looks like reflected heat damage (sunlight) from the neighbors window(s). I have seen it many times and it looks like the photos.
As for that rectangle window in the bathroom, that looks like moisture damage to the frame. Either from the inside or outside.
Finding the cause is not really your job, it is a benefit of your inspection if you can discover it but not really your primary job. If the home next door does not have any windows that face that side of the house, then I would simply report that you don't know what caused it.
Even though you did not see any sunlight being reflected onto the wall during the inspection, that does not mean it is like that all day. Early morning sunlight reflecting can be very hot. Don't forget that at this time of the year the sun is lower on the horizon so it might be seasonal.
11-14-2008, 09:44 AM #9
Has there been a fire at the home next door? Looks alot like heat damage to me. Saw a home with that type of damage that had an out building burn down next to it.
11-14-2008, 01:16 PM #10
Thanks all. I think all of the suggestions are possibilities. I'll go over with the owner whether the neighbors driveway (ten or so feet away from this side) has had a bus or large truck stored in it. Also, I'll ask about the chemicals. Reflected sunlight is possible - but why don't we see this more often? Possibly there is just the right angle with the neighbors windows? I need to ask the owner a few more questions....
Ernie Simpson
11-14-2008, 03:50 PM #11
Earnie,
I have seen the exact same thing on a deck where a grill was. Heat is the culprit.
11-14-2008, 04:07 PM #12
11-17-2008, 04:40 PM #13
Siding is damaged and in need of replacement.
What is the question?
11-17-2008, 05:21 PM #14
That is understood.
Joe,
The question is Why and How? As in Why was the siding damaged, how did it get that way?
Those answers will lead to answering the question or not of 'Should vinyl siding be put back up, or should a different type of siding be put up?'
There is a great need to know Why and How? That is the only way to best help your client understand what needs to be done.
Would it make any sense to replace that heat damaged vinyl siding with new vinyl siding when you can see what caused the first failure and you know there will be a second failure?
The answer is no, that maybe a different type of siding be used on that side of the building, if not all over.
11-17-2008, 05:24 PM #15
The one photo showed an exterior stairway to the side of the damaged siding.
Most likely BBQ Grille damage which is very prevalent in this market area....
11-17-2008, 05:40 PM #16
11-17-2008, 05:43 PM #17
Not letting the Seller off the Hook.
My original comment still stands....
"Siding is damaged and in need of replacement."
11-17-2008, 06:03 PM #18
Playing the Devel's advocate here! Is the siding not functioning as intended? I don't see a problem with it being an effective rain screen. Though more expensive than paint, it still is cosmetic damage.
Well just looked again and saw the gap at the butt joint. It there were not any gaps, as I see mostly, would it be more than cosmetic?
11-17-2008, 06:06 PM #19
11-17-2008, 06:12 PM #20
Joseph, you beat me to the punch. I am sitting in the dark while wife watches TV and can't see the keys.
11-17-2008, 06:15 PM #21
11-17-2008, 06:21 PM #22
That's funny. I was going to say barbecue myself.
Even if there were not gaps at the joints. It is destroyed and needs replacement.
You don't always know the cause and in the case of a home inspector, if you don't know, oh well. It still needs replacing. Of course that does not mean anyone has to replace it just cause you wrote it up.
11-17-2008, 06:25 PM #23
11-17-2008, 06:40 PM #24
It is not the size of the grille that determines the damage but the placement in proximity to the siding....[/quote]
Is it inversly proportional to the I.Q. of the user?
11-17-2008, 07:28 PM #25
11-18-2008, 06:06 AM #26
You have to remember, the major function of siding is aesthetics.
So. if it doesn't look good, it's not performing as intended.
11-19-2008, 04:33 PM #27
The major function is to shed water and keep the wall assembly dry, aesthetics is built into the design.the major function of siding is aesthetics.
For a shutter to warp like that it was heat. Did the neighbors burn there leaves to close to the home?
Does that side face the east or west? West being the worst in the heat of the day.
I have seen this happen from reflection of a window into the inside corner of a wall. It also had foil board substrate. Never seen it on any other type of wall assembly except foil. Have seen grills melt siding though but that has nothing to do with sun or reflective heat from the foil.
11-19-2008, 06:19 PM #28
Not vinyl siding.
Vinyl siding is required to have a WRB behind it because everyone KNOWS water will get behind it. It IS NOT designed to be water tight.
And that "design" has been affected, has it not?aesthetics is built into the design.
Thus, that siding "is not" performing its intended purpose, and that applies to 'both' "intended" purposes:
1) Keeping most of the water off the WRB behind the siding. With it warped like that, that "intended function" just ain't gonna happen.
2) Looking pretty. With it warped like that, it does not look "pretty".
Thus, that siding has failed both of its intended functions. Meaning that siding IS NOT performing its intended function(s).
Last edited by Jerry Peck; 11-20-2008 at 10:17 AM. Reason: to fix a quote "[", I had a "{" there
11-20-2008, 05:52 AM #29
HMMMMM ..........wonder why they make so many styles and colors of siding, maybe it affects their ability to shed water?
11-20-2008, 06:05 AM #30
Let me re-word that Jerry because you are correct about Vinyl.
The major function is to shed water, aesthetics is built into the design.
Jim do you really believe that siding is only there to look good?
11-20-2008, 06:23 AM #31
Nope. It's ALSO there for weather protection. However, people agonize over the appearance of it. That explains the color and style choices. Therefore, the appearance is a major function of the siding, particularly since the average buyer doesn't even consider the fact that it provides weather protection, they just want it to look good.Incidentally, if it is severely deformed at the edges, its ability to function as weather protection is most likely compromised as well.
11-20-2008, 12:01 PM #32
Jim I agree but you had it backward in your statement.
Function first (shed water) looks second.You have to remember, the major function of siding is aesthetics
And yes no one is disagreeing that that warped siding should be replaced.
11-20-2008, 12:32 PM #33
[quote=Mike Schulz;63075]Jim I agree but you had it backward in your statement.
Mike,
Jim didn't have it backward as much as he did just one word off ...
"the major function of siding" should have been "a major function of siding ".
BOTH are 'major functions of siding'.
Just like I say with paint: Paint is not cosmetic, the COLOR of the paint is cosmetic, but the PAINT is not.
Same thing for roof tiles: The roof tiles are not cosmetic, the COLOR and STYLE of the roof tile is cosmetic, but the TILE is not.
11-22-2008, 02:46 PM #34
Grille.
I blame all unexplained spellings on the French. I hope they're paying royalties on the ones they use on paper but not in pronounciation.
11-22-2008, 04:37 PM #35
11-22-2008, 05:22 PM #36
Jeez, Billy, how's a guy supposed to get to sleep tonite with that image in mind?
11-22-2008, 06:08 PM #37
