Thread: Window flashing caps
05-18-2007, 06:41 AM #1
Similar Threads:Last edited by Jeff Eastman; 12-19-2007 at 04:38 PM.
05-18-2007, 05:05 PM #2
Re: Window flashing caps
The rule I remember is that flashing is required when vertical distance from the bottom of the eave to the top of the trim is more than one-quarter of the horizontal overhang of the eave. When I Google that, however, i only turn up references to Canadian requirements.
05-18-2007, 05:43 PM #3
I'm guessing that if you look up some manufacturer's installation instructions, and if they address flashings (as most do) you will find that *they* want their windows flashed - regardless where the window it.
Because *they* don't want leaks associated with *their* windows.
05-18-2007, 08:39 PM #4
I would suspect that window manufacturers paying warranty claims on window flashing leaks is just second to shingle manufacturers paying water damage claims.
- Paul Fix
05-20-2007, 05:28 PM #5
Personally I'd let it go. If the wind was strong enough to get rain that far under the eaves then the homeowner will have more than flashing to worry about.
