Results 1 to 18 of 18
Thread: EZ-Wall
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default EZ-Wall
    I observed this installation today on a retrofitted 40s house in Dallas. The sheathing, where visible, appeard to be 1" Celotex, maybe Quick-R. I cut this piece out of a gable in the attic. I also saw some expanded polystyrene in some places, but only glimpses of it. There was no way to remove any utility escutcheons or cover plates, as they had them all sealed in place.
    As you can see from pictures in the attic at the base of the system in the dormer walls there is expanded metal visible.
    My best guess is that it is Celotex Quick-R Polyiso with some locally manufacturered scheisse called EZ-Wall (an EIFS coating). This is a new one on me. Any ideas?
    Attached Files Attached Files
    A.D. Miller Guest
    Default Re: EZ-Wall
    Yo! Is anyone out there?
    Default Re: EZ-Wall
    (your echo)
    I'm out here but am not familiar with those products or their installation. Sorry, no help there.
    A.D. Miller Guest
    Default Re: EZ-Wall
    (your echo)
    JP: Shoot! I was hoping I could get some real help with this one. Short fuse. The bullet must fly by 3:30.
    Thanks anyhow.
    A.D. Miller Guest
    Default Re: EZ-Wall
    Thanks anyhow.
    Wow, it really is quiet on there. Is this a Zen holiday?
    A.D. Miller Guest
    Default Re: EZ-Wall
    Ohmmmmmmmmmmmmmmmmmmmm
    Connecticut
    Default Re: EZ-Wall
    Sorry, Not much help here either, and past the due date by now but.
    It appears the installed was also a golfer so he gets a 50% good guy vote for that.
    Or is that your Footjoy toolbag, in which case you get 100% good guy votes
    Did you call the # on the bucket?
    A.D. Miller Guest
    Default Re: EZ-Wall
    Wayne: OK. Nope, not my golf crap. I called the number, but they had kicked the bucket!
    That bird has flown, but thanks for calling me back from the other plane.
    Garland, TX
    Default Re: EZ-Wall
    Aaron,
    Just noticed your post this a.m. they relocated if I'm not mistaken.
    Stucco Dallas Texas
    Default Re: EZ-Wall
    Sorry, I just found this post as well..
    I have not heard of it either.
    A.D. Miller Guest
    Default Re: EZ-Wall
    Thanks ya'll.
    Namaste.
    RANDY NICHOLAS's Avatar
    RANDY NICHOLAS Guest
    Default Re: EZ-Wall
    AD,
    it looks like the insulation installed on EPMD or flat roofs.
    someone must have said "I'll stuff this in there"
    Stephen Meyer's Avatar
    Stephen Meyer Guest
    Default Re: EZ-Wall
    EZ Wall Evaluation Report attached:
    A.D. Miller Guest
    Default Re: EZ-Wall
    Quote Originally Posted by Stephen Meyer View Post
    Stephen: Can you post that pdf file again? That one is corrupted, at leat on my machine.
    Thanks,
    Aaron
    Default Re: EZ-Wall
    Thanks,
    Aaron
    Here you go
    A.D. Miller Guest
    Default Re: EZ-Wall
    Here you go
    Ted: Thanks, but I had the same problem. If I use Acrobat to open it I get the first message below. If I use Acrobat Reader I get the second message below. In both instances I get 3 blank pages followed by two with something actually there.
    Default Re: EZ-Wall
    Check your mail and get rid of acrobat
    Stephen Meyer Guest
    Default Re: EZ-Wall
    Type in your browser for ES Reports. In the search box of that web page, type in EZ Wall.
    You will get a list of related reference. The first one has the testing data
    This link may work as well
    ICC-ES Search Results
    or this one
    http://www.icc-es.org/reports/pdf_files/UBC/5146.pdf
    You may want to download the pdf reader called Fox-it reader. Free and very good
    Steve
