Results 1 to 26 of 26
05-14-2009, 12:17 PM #1
oily stains on hardboard and wood siding
hey all
sorry i don't have any pictures but i think you have all seen them. what are those oily stains on hardboard and wood siding. i thought there was an old thread on this, but i couldn't find it
thanks
cvf
05-14-2009, 01:20 PM #2
Re: oily stains on hardboard and wood siding
Do you mean the tannin's in the wood seeping out through the painted surface?
05-14-2009, 01:25 PM #3
wayne
if that is what they are called--YES
cvf
05-14-2009, 03:02 PM #4
I'm not sure what stains Charlie is referring to, but hardboard siding would not have tannin staining,
05-14-2009, 03:39 PM #5
I wonder if he is thinking of the oily stains on siding that is caused from rodents entering an opening?
Just thinking here.
05-14-2009, 03:41 PM #6
05-14-2009, 03:45 PM #7
In my best Elvis voice
Thank you! Thank you very much.
05-14-2009, 04:05 PM #8
Charlie, I am sure you've already gooooooogglled it, but if not do, and usually as I have found is a problem with lack of or poor priming practices a well as an occassional termite of carpenter ant bladder problem
05-14-2009, 04:20 PM #9
05-14-2009, 04:35 PM #10
hey thanks
i have the inspector in my group asking question sending me some pictures--stay tuned
charlie
05-14-2009, 04:43 PM #11
05-14-2009, 05:01 PM #12
HERES SOME PICTURES--it is even different then what i've seen--any ideas
charlie
05-14-2009, 05:02 PM #13
sorry didnt load
05-14-2009, 05:13 PM #14
hey, i'm the inspector, here's the pics....
the home was built in '92, this condition is evident on other homes in the neighborhood. it is prevalent all over the home including the fascia boards.
homes are in denver, co
thanks for your replies and advice...
tom di iulio
win home inspection
05-14-2009, 05:31 PM #15
Tom,
Welcome to the Board.
Denver Recorded 3.06 inches of rain in April.
I could not find data on May. ( rained lately? )
Perhaps the stain on the home is a latex product that has allowed moisture to soak through in the lighter applied areas of staining.
05-14-2009, 06:46 PM #16
hey tommy boy
if this is all over the hood, has the hoa done anything about it with the builder. that is one ugly hood and somebody should have bitched about it
charlie
05-14-2009, 07:10 PM #17
05-14-2009, 07:16 PM #18
Look's like mildew stains from lack of sunlight and ventilation. paint with a Mildewside may work but a bi annual power washing would aslo work wonders.
05-14-2009, 07:25 PM #19
good points boys.....
as the condition is consistent on all sides of the home (and others in the neighborhood), i lean away from mildew issues.
i am beginning to consider paint as the issue and not the siding.
the siding itself is in good condition with no delamination or other visible signs of deterioration.
i'm wondering if a new paint application beginning with a primer or other sealing product (Kilz?) might solve the issue although only time would really tell.
hmmmmm......
05-14-2009, 07:34 PM #20
05-14-2009, 07:40 PM #21
Seen this same thing once on a home and the guy told me that his landscape company had sprayed dormat oil all over the outside for some kind of pest.
Just a thought. Maybe everyone is using the same guy.
05-14-2009, 07:48 PM #22
If it's hardboard I would not go scraping that stuff.
If it is like that on many houses throughout that subdivision you could contact a good local paint distributor to come out, look at it to make sure it was a suitable substrate for their paint, then ask them to give you a product schedule and a specification for preparation.
With it prevalent throughout the subdivision, and being as most homes were likely constructed at the same time, it is quite possible that it is something with the siding, the manufacturing of that siding, the storage of it, the preparation prior to installation, the installation of it, and even the original painting of it.
My guess is that it would be prudent to remove some and look at the back side of the siding and the wall structure, sheathing/no sheathing, insulation condition, etc.
05-14-2009, 09:15 PM #23
I wonder if it is some of that alkyd latex, where they try to mix oil and water based paints. Then if it sat in the pail too long, maybe you'd get that kind of blotchy mess. Might be hard to remedy, too.
05-15-2009, 05:09 AM #24
Was it definitely paint? Could it have been a solid hide stain? Paint is capable sealing in many applications; however, stains allow for bleeding. If the it is hardboard that was stained it will most likely turn ugly.
05-15-2009, 04:28 PM #25
I googled wax bleeding and came up with this site, Sounds like your problem. Thanks Fritz.
Wax Bleeding on Hardboard Siding
http://acloserlookslc.com/
05-16-2009, 10:08 AM #26
Hi All &
Possible this 'hood is under a flight-path ?
Could be an oil-leak, spewing...
CHEERS - from Canada's WET West Coast
-Glenn Duxbury, CHI -License #47730
-Glenn Duxbury, CHI
