Results 1 to 2 of 2
    brianmiller's Avatar
    brianmiller Guest
    Default Access panel installed on exterior wall
    A metal access panel cover, about 1/8 of inch thick or so, was installed in the stone veneer to access the master bathroom hydromassage tub plumbing/pump, etc....
    Question: The metal cover does not provide the proper exterior wall insulation value, correct? There wasn't any insulation behind the tub, just a straight view to the tub components.
    bm
    Default Re: Access panel installed on exterior wall
    Quote Originally Posted by brianmiller View Post
    Brian,
    Because they did not think about it.
    My guess is that they did not insulate any of the wall below the tub.
    I used to find those two things all the time - no insulation behind the access doors and no insulation on the walls below the tub.
    Also, if you are in Florida and where hurricane shutters are required, those doors require a shutter as they are not impact rated.
