Results 1 to 1 of 1
Thread: vinyl drainage track
09-01-2009, 06:53 PM #1
Hello, on an inspection today I came across a house with hard coat stucco around the house and foam board at the front porch and around the chimney. I did not observe a vinyl drainage track along the base of the foam board covered areas. Is this required at areas installed at the front porch and chimney. Thanks
