Results 1 to 16 of 16
    Jon mackay's Avatar
    Jon mackay Guest
    Default Is this masonite siding?
    This siding seemed very easy to damage. It was really soft and it appears that the original surface has worn leaving just the paint to protect it..
    F.I.R.E. Services
    A.D. Miller's Avatar
    A.D. Miller Guest
    Default Re: Is this masonite siding?
    It appears to be.
    Nov 2009
    St Paul, MN
    It's impossible to tell for sure without removal of the siding and reading the stamps on the back. Masonite is a brand of compressed fiberboard siding, like Kleenex is a brand of facial tissue.
    If the question was "Is this compressed fiberboard siding?" then the answer would be yes it is.
    MinnesotaHomeInspectors.com
    Minnesota Home Inspectors LLC
    Mar 2008
    Charlotte NC
    In my reports I refer to it as "hardboard siding" as Masonite is a brand name.
    Jon mackay's Avatar
    Jon mackay Guest
    Good point and thank you. Hardboard or compressed fiber may be a better description.
    Other than maintaining the paint here, are there any other concerns with this type of siding? If the original surface wears as in the pictures, will paint be sufficient to prevent further issues?
    Mar 2008
    Charlotte NC
    Quote Originally Posted by Jon mackay View Post
    Over driven nails is the most common problem I see. All over driven nails need to be sealed or the board will swell up like a poisend pup. The other thing to look for is paint on the bottom edge of the bottom course, almost always over looked.
    David Bell's Avatar
    David Bell Guest
    Depending on age the other problem is asbestos.
    Sep 2008
    Texas
    Back in the 70's the hardboard siding wasn't so hardboard. There was a time in the construction industry that this type of siding was used quite a bit and it wasn't worth nailing up, it was so soft that you could very easily break it without much effort, but the builders loved it.
    I bet this is that type of hard(soft)board.
    Jon mackay's Avatar
    Jon mackay Guest
    That sounds like what this is. It certainly is not hard, I could indent it with my finger. It doesn't seem like a great siding product..
    Colorado Springs, CO
    To protect the material from moisture:
    Seal overdriven nails.
    Install corner caps and joint covers.
    Seal all penetrations.
    Don't install the siding within 3" of soil or flat surfaces.
    Bruce Breedlove
    www.avaloninspection.com
    chris mcintyre's Avatar
    chris mcintyre Guest
    ........ swell up like a poisend pup.
    Jon,
    We see, and replace, a lot of this siding. In my area, very seldom was a moisture barrier installed, occasionally felt was put on the walls, but usually when the siding reaches the condition in your pics, the damage is beyond just the siding.
    Jon mackay's Avatar
    Jon mackay Guest
    Yes, if only I could rip the siding off and look.
    I think I'll stick with what I can see and leave it at that. These are the frustrations with being a home inspector.. No destructive investigation allowed...
    Not sure if this applies but worth reading maybe.
    Masonite Siding Lawsuit: Claim Source One
    Clarksville Home Inspection
    JW Goad
    Jon, I was not suggesting that you rip the siding off!
    You asked if there were any other concerns with this type of siding. I was simply letting you know what I have encountered with type of siding......that's all.
    Jon mackay's Avatar
    Jon mackay Guest
    Sorry, I didn't mean that in a negative way I know you were not suggesting that.
    No worries... Sometimes I really do wish I could take just a little peak...
    john_opwin's Avatar
    john_opwin Guest
    The surface looks very britlle.
