Results 1 to 14 of 14
    Colorado Springs, CO
    Default Cantilevered Lintels
    That's what we like to see - a lintel supporting the brick veneer at every window opening.
    Not sure how far back the masons ran the lintels into the brick veneer but I hope it was more than the normal bearing of the other lintels.
    Bruce Breedlove
    www.avaloninspection.com
    Bert de Haan's Avatar
    Bert de Haan Guest
    Default Re: Cantilevered Lintels
    Quote Originally Posted by Bruce Breedlove View Post
    I can see it needs a lintel with this design but when the arch is where it normally is (where it should be) an lintel doesn't add anything to the strength.
    A.D. Miller's Avatar
    A.D. Miller Guest
    This is a Venetian arch which should have a proper lintel:
    Venetian Arch Lintel - Catnic - Special lintel with venetian arch
    Venetian Arch
    Bert de Haan Guest
    Thanks A.D. I didn't realize this design actually came with a name. This type of arch sure does away with the structural benefits of an arch and are left just with the aesthetics.
    Ridgewood, NJ
    The more common name for this is a Palladian window.
    Quote Originally Posted by Bert de Haan View Post
    Only in modern construction.
    Back in the day the arch performed as designed by bearing on the center structural supports between the windows, with the two side windows being flat top from the side bearing to the center bearing points where the arch was also bearing.
    Advance backward (in this case, along with some other cases) to modern construction and the full width needs to be spanned with a header as there are no center supports, just "frames" between the windows. Now, the opening is no longer (as an example) a 4 foot arched opening flanked with 2-3 foot flat top openings with center supports ... the opening is now a full 10 feet wide and requires some structural support suitable for that full 10 foot width - which means the load on the bearing at the ends is now MUCH GREATER too.
    Bert de Haan Guest
    Thanks Jerry. Now I also understand why one of the links of the OP said:...giving an outstanding traditional appearance.
    OK. But is that continuous lintel a requirement, or just a Good Idea (tm)?
    A.D. Miller Guest
    NL: The common element of Palladian arches, which distinguishes them from the Venetian (Queen Anne) arches is the supports below the arched opening. So then, the photo in the original post depicts a Venetian, and not a Palladian, arch.
    From the Brick Industry Association's Technical Note 31 - Brick Masonry Arches.
    Aug 2009
    Michigan
    A.D. thanks for the pics on the lintel support... I have never seen one of those. That's why I like hanging around here, learn something new all the time.
    However, I don't see even the slightest hint of movement in any of the brick pictures. It appears that whatever the mason did, it's working, atleast for now. I don't even see any hairline cracks?
    Randy Gordon, construction
    chris mcintyre's Avatar
    chris mcintyre Guest
    I did not notice that it was a 1/2 round window sitting on a wider window, which (I have just learned) meets the Venetian criteria.
    So am I correct in that the lintels in post #3 are Venetian lintes because they are one piece and do not require support at the corners of the arch, and are pictured with a Palladian window?
    Yes, because that Paladin window does not really have the center supports of old, only fake supports separating the windows, thus the wall above needs to be supported across the entire width, thus the need to use the Venetian arch lintel.
    A.D. Miller Guest
    Quote Originally Posted by Door Guy View Post
    DG: It will probably function just fine where it is located. Put it in a house atop the most expansive clay soil in the US, and it will be a different story.
    Aug 2009
    Michigan
    We have various soils here in Michigan. Even the expansive clays, I think they really can be built on if done correctly (not ideal though). The funny thing here is such a mix. I built a house about 20 years ago, we dug the basement and the front half was slippery red clay, the back of the hole was like beach sand. That concerned me having the foundation on two soil types, but everything was just fine and is still good now.
